Prevent OK from sending mails
  • rwagner1972
    • Jan 2017
    Good morning,
    Can someone please tell me how to prevent Zabbix 3.2 from sending an email when the status is OK?
  • sancho
    • Mar 2015
    • 301
    I have the same problem with version 3.2.3, mails do not arrive with status OK.
    What "Recovery Expression" should be configured?
    • batchenr
      • Sep 2016
      • 440
      Originally posted by rwagner1972
      Good morning,
      to prevent at the Configuration -> Actions
      press at your action and remove the V from check box "Recovery message"
      and it will prevent the sending
      • sancho
        • Mar 2015
        • 301
        Hi batchenr,
        Sorry, I need exactly the opposite, someone could tell me what to configure to send the mails with status OK in version 3.2.3. In this version there is no check box "Recovery message".
        I have more than 2000 triggers and now no one informs me when the problem has been fixed.
        • batchenr
          • Sep 2016
          • 440
          Originally posted by sancho
          Hi batchenr,
          there is a box- look closly.
          press at the action name and there at the bottom left
          screen shot if you cant find
          • SBO
            • Sep 2015
            • 226
            In Zabbix 3.2.3, I have a "Recovery operations" tab, where you can set it up.
            Ex: https://snag.gy/hNJ8yI.jpg
            • sancho
              • Mar 2015
              • 301
              Forgives,
              But it does not appear, attached image
              • batchenr
                • Sep 2016
                • 440
                look at this
                • SBO
                  • Sep 2015
                  • 226
                  Forgives,
                  You have the "Recovery operations" tab on your image..
                  • rwagner1972
                    • Jan 2017
                    Batchenr.. That solved it for me! Thank you
                    • sancho
                      • Mar 2015
                      • 301
                      Thank you very much for your help batchenr and SBO,
                      That was what was missing, I did not notice that the tab did not exist in the previous version !!!
                      a greeting
