How to monitor zabbix server itself?
  • CSYI
    • Apr 2024
    I wish to know if zabbix server is down, will noticed by e-mail from zabbix itself?
  • Answer selected by CSYI at 13-09-2024, 01:37.
    cyber
    It is always the question, "who watches the watchers"..
    You can create a simple check script and run it from crontab for example... If server process(es) are not found, send an email .. or something.
    • CSYI
      CSYI commented
      Thanks.
      Think about it a bit more.
    It would be like "Do you notice, if you are dead? Will you tell others? "...
    • CSYI
      CSYI commented
      yeah, NO DOUBT as you tell.
      I don't want to use more monitoring tools to monitor the monitoring tools. lol
    • CSYI
      CSYI commented
      Thanks.
