problem of zabbix agent in windows
  • MKP
    • Jan 2017
    I am monitoring MS SQL server and IIS in windows server 2016 through zabbix 3.2 and the agent is installed on the server.
    I have configured zabbix agent in active mode.
    when i start the zabbix-agent service after some seconds it stops.
    i reviewed the logs says "App crash" has happened.
    here is the crash report from windows:
    Version=1
    EventType=APPCRASH
    EventTime=131302342298397951
    ReportType=2
    Consent=1
    UploadTime=131302342326054304
    ReportIdentifier=1c7daa8c-e6bc-11e6-9986-000c29ab7fcb
    IntegratorReportIdentifier=bacc9468-fea6-4deb-9777-4953298f71a3
    NsAppName=zabbix_agentd.exe
    AppSessionGuid=00002bfc-0000-0008-b985-5bd0c87ad201
    TargetAppId=W:0006a76994f12e609cc0c67c325c060c9a71 00000904!0000a6c4d98300f4558942387a3654a62dc51ea6c ecd!zabbix_agentd.exe
    TargetAppVer=2014//10//08:06:38:20!6c174!zabbix_agentd.exe
    BootId=4294967295
    Response.type=4
    Sig[0].Name=Application Name
    Sig[0].Value=zabbix_agentd.exe
    Sig[1].Name=Application Version
    Sig[1].Value=2.4.1.49637
    Sig[2].Name=Application Timestamp
    Sig[2].Value=5434dbdc
    Sig[3].Name=Fault Module Name
    Sig[3].Value=zabbix_agentd.exe
    Sig[4].Name=Fault Module Version
    Sig[4].Value=2.4.1.49637
    Sig[5].Name=Fault Module Timestamp
    Sig[5].Value=5434dbdc
    Sig[6].Name=Exception Code
    Sig[6].Value=c0000005
    Sig[7].Name=Exception Offset
    Sig[7].Value=000000000001c68f
    DynamicSig[1].Name=OS Version
    DynamicSig[1].Value=10.0.14393.2.0.0.272.79
    DynamicSig[2].Name=Locale ID
    DynamicSig[2].Value=1033
    DynamicSig[22].Name=Additional Information 1
    DynamicSig[22].Value=27da
    DynamicSig[23].Name=Additional Information 2
    DynamicSig[23].Value=27daad155976d6291ce48be5c79a9b18
    DynamicSig[24].Name=Additional Information 3
    DynamicSig[24].Value=637f
    DynamicSig[25].Name=Additional Information 4
    DynamicSig[25].Value=637f61acf51339acc4791ea236f948cc
    UI[2]=C:\zabbix_agentd.exe
    UI[5]=Check online for a solution (recommended)
    UI[6]=Check for a solution later (recommended)
    UI[7]=Close
    UI[8]=zabbix_agentd.exe stopped working and was closed
    UI[9]=A problem caused the application to stop working correctly. Windows will notify you if a solution is available.
    UI[10]=&Close
    LoadedModule[0]=C:\zabbix_agentd.exe
    LoadedModule[1]=C:\Windows\SYSTEM32\ntdll.dll
    LoadedModule[2]=C:\Windows\System32\KERNEL32.DLL
    LoadedModule[3]=C:\Windows\System32\KERNELBASE.dll
    LoadedModule[4]=C:\Windows\System32\WS2_32.dll
    LoadedModule[5]=C:\Windows\System32\sechost.dll
    LoadedModule[6]=C:\Windows\System32\RPCRT4.dll
    LoadedModule[7]=C:\Windows\System32\PSAPI.DLL
    LoadedModule[8]=C:\Windows\System32\ADVAPI32.dll
    LoadedModule[9]=C:\Windows\System32\msvcrt.dll
    LoadedModule[10]=C:\Windows\System32\USER32.dll
    LoadedModule[11]=C:\Windows\SYSTEM32\pdh.dll
    LoadedModule[12]=C:\Windows\System32\win32u.dll
    LoadedModule[13]=C:\Windows\SYSTEM32\IPHLPAPI.DLL
    LoadedModule[14]=C:\Windows\System32\GDI32.dll
    LoadedModule[15]=C:\Windows\SYSTEM32\DNSAPI.dll
    LoadedModule[16]=C:\Windows\System32\gdi32full.dll
    LoadedModule[17]=C:\Windows\System32\NSI.dll
    LoadedModule[18]=C:\Windows\System32\ole32.dll
    LoadedModule[19]=C:\Windows\System32\combase.dll
    LoadedModule[20]=C:\Windows\System32\ucrtbase.dll
    LoadedModule[21]=C:\Windows\System32\bcryptPrimitives.dll
    LoadedModule[22]=C:\Windows\System32\OLEAUT32.dll
    LoadedModule[23]=C:\Windows\System32\msvcp_win.dll
    LoadedModule[24]=C:\Windows\system32\mswsock.dll
    LoadedModule[25]=C:\Windows\SYSTEM32\dhcpcsvc6.DLL
    LoadedModule[26]=C:\Windows\SYSTEM32\dhcpcsvc.DLL
    LoadedModule[27]=C:\Windows\System32\perfos.dll
    State[0].Key=Transport.DoneStage1
    State[0].Value=1
    FriendlyEventName=Stopped working
    ConsentKey=APPCRASH
    AppPath=C:\zabbix_agentd.exe
    NsPartner=windows
    NsGroup=windows8
    ApplicationIdentity=AFB0D7C3A8729E630D80EAFD82B4E7 C2
    MetadataHash=-977299397
  • batchenr
    • Sep 2016
    • 440
    Version=1
    EventType=APPCRASH
    ReportType=2
    Consent=1
    BootId=4294967295
    Response.type=4
    UI[7]=Close
    UI[10]=&Close
    State[0].Value=1
    ConsentKey=APPCRASH
    NsPartner=windows
    NsGroup=windows8
    try adding Debug to zabbix_agent conf maybe it will get more info
    or i can recommand you to install zabbix agent from here
    i did and it works fine.
    • tim.mooney
      • Dec 2012
      • 1432
      You may be running Zabbix 3.2 on your monitoring server, but this system with the crashing agent has version 2.4.1. If you're going to run an agent from the 2.4 series, at least use the latest version in the series. There have been lots of fixes since version 2.4.1.
      • MKP
        • Jan 2017
        Solved
        Thanks.
        Upgrading the agent solved the problem.
        • MHHosni
          • Mar 2024
          Dear All,
          i have Zabbix agent 6.4.0 installed on windows server 2019 and every couple of hours the following error comes up : Receiving an error Zabbix 111 connection refused?
          and the service is stopped.
          I have found an error log in windows event viewer and found the following :
          Faulting application name: zabbix_agentd.exe, version: 6.4.0.2400, timestamp: 0x64072d9e Faulting module name: ntdll.dll, version: 10.0.17763.5458, time stamp: 0xfb111856 Exception code: 0xc0000374 Fault offset: 0x00000000000fb209 Faulting process id: 0x8fc Faulting application start time: 0x01da74778b042692 Faulting application path: C:\Program Files\Zabbix Agent\zabbix_agentd.exe Faulting module path: C:\Windows\SYSTEM32\ntdll.dll Report Id: 65fe3f66-070d-4fd3-b189-a15be8d53f77 Faulting package full name: Faulting package-relative application ID:
          what is the meaning of the error as i dont understand what is the problem regarding this issue?
          Thank you
