Problem It probably means that the systems requires more physical memory
  • sby
    • Jan 2017
    • 59
    How can i fix this issue.
    I use KVM VPSen and want monitoring with zabbix.
    I have CentOS 7 64 BIT en zabbix 3.0.1
    I have this error every day.
    Lack of free swap space on server1.demo.com
    I hope some one can help me.
  • batchenr
    • Sep 2016
    • 440
    on which server you see it ?
    the zabbix server or is it an agent alerting ? if its an agent check the swap
    and if it is full.
    please add more info
    • sby
      • Jan 2017
      • 59
      I see this on a server where is installed a Zabbix Agent.
      The Zabbix Agent is installed on a ubuntu 14.04 server.
      The swap is normal in the server self.
      Only zabbix say the error message
      The swap is 0 in the ubuntu so the problem is solved.
      Zabbix say it is a problem.
      • batchenr
        • Sep 2016
        • 440
        run this on zabbix server :
        zabbix_get -s REMOTESERVERIP -p 10050 -I ZABBIXSERVERIP -k system.swap.size[,used]
        and
        zabbix_get -s REMOTESERVERIP -p 10050 -I ZABBIXSERVERIP -k system.swap.size[,free]
        Replace ZABBIXSERVERIP with your zabbix server ip address
        and REMOTESERVERIP on remote servers that making this issue,
        and can you please post the trigger ?
        my trigger looks like this :
        {server.dev:system.swap.size[,pfree].last(0)}<50
        pfree - show the percentage of swap space is free , you can run this as well - and if its 50% used space of swap space its alerting.
        • SBO
          • Sep 2015
          • 226
          If the server doesn't have swap, monitoring it is useless. You should deactivate it.
          I have the same situation on some OVH servers that I rent, they're configured by default with no swap space.
          • sby
            • Jan 2017
            • 59
            I have no command zabbix_get when i use that the system says command not found
            • batchenr
              • Sep 2016
              • 440
              install it
              • sby
                • Jan 2017
                • 59
                Since i have install zabbix-get my zabbix is broken.
                It will not start again.
                32692:20170131:125729.886 ****** Enabled features ******
                32692:20170131:125729.886 SNMP monitoring: YES
                32692:20170131:125729.886 IPMI monitoring: YES
                32692:20170131:125729.886 Web monitoring: YES
                32692:20170131:125729.886 VMware monitoring: YES
                32692:20170131:125729.886 SMTP authentication: YES
                32692:20170131:125729.886 Jabber notifications: YES
                32692:20170131:125729.886 Ez Texting notifications: YES
                32692:20170131:125729.886 ODBC: YES
                32692:20170131:125729.886 SSH2 support: YES
                32692:20170131:125729.886 IPv6 support: YES
                32692:20170131:125729.886 TLS support: YES
                32692:20170131:125729.886 ******************************
                32692:20170131:125729.886 using configuration file: /etc/zabbix/zabbix_server.conf
                32692:20170131:125729.887 cannot set resource limit: [13] Permission denied
                32692:20170131:125729.887 cannot disable core dump, exiting...
                How can i fix it and what resource is permission denied
                • batchenr
                  • Sep 2016
                  • 440
                  turnoff Selinux
                  • sby
                    • Jan 2017
                    • 59
                    Thank you.
                    I have finaly everything works and now try you command of zabbix get
                    But i get as output 0
                    zabbix_get -s xxxx -p 10050 -I xxxxx -k system.swap.size[,used]
                    0
                    0
                    • batchenr
                      • Sep 2016
                      • 440
                      Thank you.
                      0
                      0
                      what is this server ? if you go to the server itself and run free -m what is the results ?
                      thats why zabbix fire a trigger about it , 0 make it think there is no space
                      • SBO
                        • Sep 2015
                        • 226
                        That's what I said in my first post in this thread.. The server has no swap, it's useless to monitor it..
                        • sby
                          • Jan 2017
                          • 59
                          Thank you i have now disabled the message so when i try free -m i see 0 so thank you for your help.
                          • Kachou
                            • Feb 2020
                            • 10
                            Hello zabbix community,
                            Sorry re-open this post.
                            I have the same problem but I think I have a swap.
                            This is what I have as a result with 'zabbix_get' (images)
Name:	swap - zabbix_get.jpg
                            REMOTESERVERIP = 192.168.4.14 (WINDOWS)
                            ZABBIXSERVERIP = 192.168.4.135 (CENTOS 7)
                            Thank you in advance for your help.
                            Kachou
