ZBX cloud how to integrate with cisco switch to monitor (SNMP or API)
  • nczaw
    • Sep 2023
    • 31
    Hi all,
    I registered for ZBX cloud service and now I can start access ZBX frontend then how can i integrate my cisco switch to monitor from ZBX cloud ?
    • 5008
    Just as from your on-prem instance, I guess... It is your responsibility to create necessary accesses... But I would suggest youto use a proxy for that. Reduces significatnly the amount of FW holes you might need.
    • nczaw
      nczaw commented
      Hi cyber thank for your reply and it there have any guide for monitoring with ZBX cloud to any host ?
    • 5008
    You clearly did not read my answer...
    Treat it as its just another zabbix instance... Think of it as you just set up another Zabbix instance in different datacenter and you have to point everything there now... There is no speical "cloud config" for things...
