Getting monthly metrics in numbers.
  • Jonathan2260
    • May 2023
    • 12
    I am wondering if I have Zabbix monitoring a connection such as a ping and provide numbers such as the average ping for a month and email it.
  • tim.mooney
    • Dec 2012
    • 1437
    Zabbix 6.0 and later support scheduled reports: https://www.zabbix.com/documentation...config/reports
    You build a dashboard with the information you want in the report, then schedule that dashboard to be emailed to the configured users.
    • Jonathan2260
      • May 2023
      • 12
      Thanks for the response.
      I'm on 6.0 LTS version. Can you tell me how I would put the wanted values in the dashboard?
        • 5002
        You need to create a dashboard, that contains all your required data. That scheduled reporting thing just generates the report based on that as pdf and sends to you by email...
        • Jonathan2260
          • May 2023
          • 12
          Thanks. I do understand that I need to create the dashboard. I have been fiddling with it. So far I get the impression that I need to create an Item Value type widget and that is displaying the ping ms at the current time.
          If I am on the right track, I would need to change the description {ITEM.NAME} to something else to get the average of last month.
