Snoic Firewall Syslog
  • Shehpar Hassan
    • Dec 2023
    I need to know how I can receive SonicWall firewall logs on the Zabbix server for monitoring.
    Note: I have configured the SNMP agent on Zabbix to monitor bandwidth, interface status, CPU, and RAM of the firewall, but I’m unsure how to retrieve syslogs.
    I have also attached the template through which I am receiving this information in Zabbix.
    log monitoring by zabbix requires Zabbix agent installed on a host... So if its just a dummy snmp device, you cannot read any logs from it directly. You need some 3rd tool, where you can probably send your logs from device and read them there...
    • Shehpar Hassan
      • Dec 2023
      Hi Cyber,
      I am using SNMP OIDs to retrieve firewall data in Zabbix. Is it possible to get syslog data through the same method? I mean, can I receive Firewall syslogs from the SNMP device?
        Eventho I have no knowledge of any SonicWall FW-s... I am pretty sure, the answer is no.
