Inc backups notworking
  • Linuxuser
    • Nov 2024
    Hi all!
    Not sure if this has come up in the past so I apologize if I am covering old ground. I am having an issue. Have an MQL (My SQL) server where /var/backup back ups are backing up, however the inc folder is not getting backups, only logs. The log says it can't find a log file from July. Full backups have been backing up to the current week. I am wondering if there is anyway to stop the backups and start again so the incremental backups look for newest log and not one 5 months ago? Would creating a dummy log help solve this issue? The MQL server is part of a innodb cluster so ideally I want to avoid restarting the server as then I would have to be careful as regards to the cluster as a whole. Is there a service that the server uses for backups?
    • 5002
    So you put a backup in your backup, so you can backup, while you back up?
    TBH, could not understand a thing.. Not really a Zabbix question, eh?
