Ceph by Zabbix Agent 2 "Empty Result"
  • cesq
    • Mar 2022
    I've been trying to set up monitoring for my Ceph cluster using the out of the box "Ceph by Zabbix Agent 2" Template for Zabbix 6.0
    Sadly I've encountered a strange error. All discovery rules and items give me an "Empty Result" error.
    Example:
    Click image for larger version  Name:	image.png Views:	1 Size:	8.7 KB ID:	495012
    I have been following the official Zabbix documentation for this, as well as Proxmox docs:
    I've done the following:
    -> Ensured that the restful ceph module is enabled and running
    -> Created a zabbix api user
    -> Made sure the API is working correctly
    I have also tested this using the zabbix_get command and got the same result.
    zabbix_get -s 127.0.0.1 -k ceph.status["https://localhost:8443","zabbix","my-api-key"]
    ZBX_NOTSUPPORTED: Empty result.
    The ceph.ping command returned "0"
    zabbix_get -s 127.0.0.1 -k ceph.ping["https://localhost:8443","zabbix","my-api-key"]
    0
    Also no errors in the log file /var/log/zabbix/zabbix_agent2.log
    Using curl on the api resulted in this:
    curl -k https://localhost:8443
    HTML Code:
     <noscript>
        <div class="noscript container"
             ng-if="false">
          <div class="jumbotron alert alert-danger">
            <h2 i18n>JavaScript required!</h2>
            <p i18n>A browser with JavaScript enabled is required in order to use this service.</p>
            <p i18n>When using Internet Explorer, please check your security settings and add this address to your trusted sites.</p>
          </div>
        </div>
      </noscript>​
    Maybe this info is useful?
    I have accounted for the fact that my api is running on port 8443 and not the default 8003 and adjusted the macros and configs accordingly. I've also disabled certificate verification as I am using a self-signed cert.
    I'm completely lost here, I have done everything by the book and it isn't working. Also spent hours googling and no one seems to have had the issue I'm facing with this template. Any help will be greatly appreciated.
    Zabbix version: 6.0.34
    Ceph version: 18.2.4 reef (stable)​
  • tompaah
    • Jan 2025
    • 20
    Did you get this resolved? I get the exact same results.
    ceph.ping returns "0" and every else ceph.* -command returns "ZBX_NOTSUPPORTED: Empty result".
    Using Zabbix 7.4.6 and Ceph 20.2.0
    • cesq
      • Mar 2022
      I am going to be honest, It's been over a year and this topic has been buried under an avalanche of more pressing tasks and matters. I have long forgotten about it but what from what I recall it hasn't been solved due to internal issues with our ceph instance - a certain service not listening on the proper port (i've forgotten what is was). But do look closer at ceph rather than Zabbix in this matter. I wish I could help more, hope you get it resolved!
