PostgreSQL with timescaleDB
  • Hubert Kurowski
    • Jan 2024
    • 16
    I am using Zabbix v7.0 with PostgreSQL and TimescaleDB.
    I have two servers and the database is replicated between them.
    Do I need to configure partitioning on both servers or will the database replicate if partitioning is configured on only one server?
    If I need to configure on both servers do they need to be stopped while configuring partitioning?
    BR,
    Hubert
    • 5002
    Replication should replicate everything... Doing changes in active host will be replicated in passive.. Thats the point of replication...
    • Hubert Kurowski
      • Jan 2024
      • 16
      Thanks for the answer. I have one more related with this.
      I have set up timescaledb, hypertables and compression. Additional in Zabbix I've set up housekeeping
      History data storage period: 21d
      Trends data storage period: 60d
      Compress records older than: 7d
      but command
      SELECT * FROM timescaledb_information.jobs; does not display policy_retention column. Do I need to add retention_policy manualy on database and disable housekeeping?
      BR,
      Hubert
        • 5002
        I never added anything manually..:P I dont see such field in DB also, so I guess it does not have to be there
        • Hubert Kurowski
          • Jan 2024
          • 16
          Zabbix script for timescale only setting up compression and housekeeping. If you want to delete chunks automatically you need to add retention_policy manually. (Timescale Documentation | Create a data retention policy)
            • 5002
            That is something that housekeeper in Zabbix should do for you..
            At least here I have no issues of DB just growing.. old things are dropped as required, data is saved as defined in housekeeper settings...
