String comparison
  • chasefox
    • Mar 2017
    String comparison
    I've been having difficulty building a trigger based on string comparison. I want to be able to check if the running config matches the saved config. SNMP of the appliance gives me a value that offers a checksum of the configs, but I have been unable to compare these values in zabbix.
    If I try the straightforward approach
    {Template SNMP Adtran:adAOSStartConfigChecksum.last()}<>{Template SNMP Adtran:adAOSRunConfigChecksum.last()}
    It doesn't work because it seems <> can only compare numerical values.
    If I try a more round-about approach
    {Template SNMP Adtran:adAOSStartConfigChecksum.str({Template SNMP Adtran:adAOSRunConfigChecksum.last()})}<>1
    it doesn't work because it seems nested variables are not supported.
  • richlv
    • Oct 2005
    • 3112
    In case somebody stumbles upon this older thread - string comparison in triggers is supported since Zabbix 5.0:
