Mikrotik monitoring with Zabbix
  • ArturZnicenacka
    • Dec 2024
    Hi there.
    I have set up Mikrotik router monitoring with Zabbix using SNMP, all working fine, but I am wondering is it possible to monitor network traffic per device? What I have now is monitoring per interface. I'm not sure if this is even possible via SNMP?
    Thanks,
    Artur
  • fpawlicki
    • Dec 2024
    • 9
    Hi Artur,
    It's doable, you'd just have to enable SNMP on each of those devices. Please give documentation a read and adjust for your version of Zabbix.
    Cheers
    • ArturZnicenacka
      • Dec 2024
      What about devices that don't support SNMP? I have some IoT devices and want to monitor their bandwidth usage with Zabbix.
      • PavelZ
        • Dec 2024
        • 171
        It's quite complicated.
        I can only suggest creating firewall rules and collecting them using a script connected by ssh with keys and sending items data using zabbix-sender.
        Lots of programming work
