1264321:20241223:105819.450 received id:576177 is less than last id:576419
  • amit.z
    • May 2024
    Hey,
    I have a Zabbix server, zabbix db running MariaDB and 2 proxies also with MariaDB.
    Zabbix version is 7.0.5 and hosts are Ubuntu24.
    I started adding hosts (linux vm machines) and everything worked fine.
    Then I started adding Windows vm machines and suddenly I started to see a many logs like this:
    1264317:20241223:105818.673 received id:776280 is less than last id:776615
    I checked on the net and tried many solutions, non of them worked.
    What I am trying to understand is what causes the issue. I tried to look in the proxy db for these ids but nothing.
    I think that it related some how to a specific item or trigger but I can't put my finger on it.
    Did someone saw this kind of log?
    Thanks a lot
  • Brambo
    • Jul 2023
    • 250
    No experience, but maybe it puts you on the right track.
    What type of agent template are you using? Active or passive.
    I expect active as passive should not generate these faults.
    And if active you are in control of the hostname and I expect that more then one host is reporting with the same name.
