How to Monitor Device Restarts Using Zabbix (SNMP)
  • mrboh
    • Dec 2024
    • 12
    I have a device added to Zabbix via SNMP, and I want to simply track and display the number of times it has restarted.
    What’s the easiest way to set this up? Do I need to create a custom SNMP item or a trigger?
    I tried now for about 4 hours to do this but I simply cannot get it right
  • Blevar
    • Jan 2025
    • 68
    I would try creating a trigger which acts upon a device restart.
    Then create a dependent item which would track the number of triggers.
      Track its uptime, https://oid-base.com/get/1.3.6.1.2.1.1.3
      Creating a trigger based on it easy (last value has to be smaller than previous). But how exactly to count those cases over time...
      I'd like to hear a bit more about this..
