Oracle: Failed to fetch info data (or no data for 5m)
  • Fonzie917
    • Jan 2025
    Hello, everyone,
    I have a problem with the Oracle ODBC template, the log says so:
    Trigger Oracle:uptime returns this error Cannot connect to ODBC DSN: [SQL_ERROR]:[01000][0][[unixODBC][Driver Manager]Can't open lib ‘/usr/lib/oracle/21/client64/lib/libsqora.so.21.1’ : file not found].
    I am currently using oracle 19C on my DB, should I load new drivers in zabbix?
    To configure the connection to the db I edit the file: /etc/odbc.ini
  • Blevar
    • Jan 2025
    • 68
    Looks like you are using a template for Oracle 21c.
    You could try providing a correct path for the driver in inherited macros for your host:
