Hi everyone,
I've tried to configure this scenario but without success.
- Create a widget with Top Hosts, limit 10 based on "Linux: Load Average 5m"
- Create a widget with type Graph and select "Override Host: Widget > Top Hosts with load"
This configuration only show 1 host, the one on top of the list even if the widget shows 10.
Plus, the same behaviour is seen on Honeycomb
- Create a widget with Type Honeycomb and on Hosts select Widget > Top Hosts with load
I don't see any other option or filter to avoid this situation from documentation or configuration of widgets.
Any advise? Thank you
