zabbix crossaccount monitoring issue
  • zabbix_prakash.ashokan
    • Jan 2025
    Hello Team,
    In our environment, we have multiple AWS accounts, and all are in private networks.
    On account A, I have a zabbix proxy server
    On account B, I have a RDS server
    I am trying to implement the AWS RDS instance by HTTP template using role_base option to gather the RDS and cloudwatch data.
    When I use on the same account with role_base the data is retrieved successfully; however, it is not working for cross-account.
    What I followed from my end.
    1) created a role and added a policy as per the link on account B.
    2) Created a policy and implemented it in account A.
    3) Both account services have enough permission to access each service.
    4) However, there is no data fetched from the template. I would like to know how the Java script generates the tempaccess key and security key. (The template contains the Java script to retrieve the rds data.).
    5) If I use the key-based method, it is retrieving the data. However, we do not want to use this method due to the security policy.
    6) account A details
    Rolename: zabbix-rds-crossaccount
    "Version": "2012-10-17",
    "Statement": [
    "Effect": "Allow",
    "Action": "sts:AssumeRole",
    "Resource": "arn:aws:iam::accountB:role/cw-rds-cross-fb-account"
    readonly access for RDS and clodwatch policies
    7) account B details
    Rolename: cw-rds-cross-fb-account
    Trust relationships:
    "Statement": [
    "Effect": "Allow",
    "Principal": {
    "AWS": "arn:aws:iam::accountA:role/zabbix-rds-crossaccount"
    Error:
    390131:20250121:141300.918 [ AWS RDS ] ERROR: Request failed with status code 403: {"Error":{"Code":"AccessDenied","Message":"User: arn:aws:sts::accountA:assumed-role/zabbix-rds-crossaccount/i-instanceis not authorized to perform: cloudwatchescribeAlarms on resource: arn:aws:cloudwatch:ap-south-1:accountA:alarm:* because no identity-based policy allows the cloudwatchescribeAlarms action","Type":"Sender"},"RequestId":"76f825fe-9225-48c5-aecc-884f92142d6e"}.
    390133:20250121:105011.628 [ AWS RDS ] ERROR: Request failed with status code 404: {"Error":{"Code":"DBInstanceNotFound","Message":"DBIn stan ce rds-name not found.","Type":"Sender"},"RequestId":"f08256e8-3fe8-4d8c-a31d-289d372193c0"}.
