Good morning,
After configuring my AD Auth on Zabbix 7.2.1, the Test button works fine
However, when i try to log in, it says that the user doesn't exists or is blocked.
The issue is that if i run a wireshark/tcpdump, during the test i see the LDAP packets; but when i try to log is, i don't see any LDAP flow.
I've well ticked "Default Auth : LDAP" and specified user group for deprovisioned users
We're using other app (glpi) with AD auth too that works fine, so basically it's not a network issue
Could you help me please ?
Best regards,
Best regards,
