Long queues for Simple checks.
  • Aer0
    • Sep 2024
    • 26
    Hello everyone.
    We have a lot "Simple check" items on our Zabbix, most of them are working on VmWare Virtual Servers with different VmWare Templates.
    Than more servers we've add, than more Simple checks queues we've got.
    We want to avoide this queues, what we need to check or change in cfg-file?
  • Answer selected by Aer0 at 04-02-2025, 18:18.
    Ldzzzz
    • Feb 2024
    • 16
    You can increase your pollers or pingers for simple check in etc/zabbix/zabbix_server.conf :
    StartPollers=
    StartPingers=
    • kyus
      • Feb 2024
      • 200
      Hey!
      Have you checked the usage of Zabbix pollers and caches?
      • Ldzzzz
        • Feb 2024
        • 16
        StartPollers=
        StartPingers=
        • Aer0
          • Sep 2024
          • 26
          Originally posted by kyus
          Hey!
          We monitor all our devices from single Proxy.
          What have tried to change cfg-file on the Proxy, but we not sure we made it right.
          What we have now in /etc/zabbix/zabbix_proxy.conf
          StartPollers=15
          StartAgentPollers=15
          StartSNMPPollers=15
          StartPollersUnreachable=15
          StartPingers=1
          StartDiscoverers=5
          StartHTTPPollers=1
          StartVMwareCollectors=3
          VMwareFrequency=60
          VMwarePerfFrequency=60
          VMwareCacheSize=32M
          VMwareTimeout=120
          CacheSize=256M
          Should I change "StartPingers" to increase "Simple checks" capacity?
          • kyus
            • Feb 2024
            • 200
            You can use the Zabbix proxy health template to monitor your proxy, that way you can see some metrics about pollers and caches usage.
            If they're too high, then yeah, you should increase it.
            • Aer0
              • Sep 2024
              • 26
              Thank you everyone!
              I changed StartPingers= parameter from 1 to 15 and that helped me.
