Hi I need some help getting the SNMP connection to the Meraki dashboard to work. Yesterday when I setup the connection it worked for 5 min SMNP label was green, all the AP's were discovered then the SMNP connection went down and hasn't been up since. I set the connection up using the template for Meraki dashboard. I can ping the snmp.meraki.com from the Zabbix server, but when I use snmpwalk I get this message: Timeout: No Response from snmp.meraki.com:16100. The Zabbix server is running on an ubuntu virtual machine and has version 5.4.12. This was an inheritance, I know I should upgrade, this will be done but is not possible atm.
I am fairly new to Zabbix so if there are logs required please also explain how to get them.
Kind regards
Jasper
Kind regards
Jasper
