The Zabbix server is not running; the information displayed may not be current
  • TiranG
    • Feb 2025
    Hi all,
    I need assistance with a problem I'm encountering in our Zabbix setup.
    Current Setup:
    Zabbix Server Specs:
    RAM: 32GB
    CPU Cores: 11 Cores
    Hard Disk: 700GB
    Network Devices Added:
    Firewalls: 800 already added successfully.
    Switches: We have enabled auto-discovery for switches, but nothing is being discovered.
    Issue:
    Error Message: On the fronted, I’m seeing a message saying, "The Zabbix server is not running; the information displayed may not be current."
    Symptoms:
    The switches set for auto-discovery are not appearing in the system.
    The status of the Zabbix server is uncertain, based on the error message.
    • 5002
    And what does your system say about server status?"systemctl status zabbix_server" ?? It would be first thing to check...
    • villivateur
      • Feb 2025
      I have the same problem. The systemctl status zabbix_server shows zabbix is running. I also checked the zabbix server log, no error found.
      Also, it is strange, that the bubble contains the message disappears when my mouse hover on it.
      • johannestoger
        • Mar 2025
        I have the same issue. Zabbix seems to be working as it should. DB is up and running, all services up, but I get this warning bubble at the bottom of the screen.
        • johannestoger
          • Mar 2025
          Fixed it by making sure the Zabbix web/PHP settings were correct, and then restarting the Zabbix server and apache2.
          • wholybee
            • Apr 2025
            What settings were updated, and where?
            I am having the same issue, fresh install and seems to work, systemctl status shows zabbix is running. But page claims it is not.
