Put a switchport trigger in maintenance if the connected device is in maintenance
  • WouterPeeters
    • Jun 2024
    So I have a multiple switches connected to a central switch. If I service one of the edge switches, I put it in maintenance. But the central switch will still trigger an alert if he sees the port to the edge switch go down.
    Can I edit the trigger on the central switch, not to alert if the edge switch is in maintenance? Or some other way of reaching the same goal.
    W
    Tags? All edge switch ports and that one central switch port shoudl have somekind of a tag with same value. Then you can create maintenance criteria based on tag value... And even if problem is fired, it will not be escalated..
