Hi all,
I have a server which has Zabbix installed on it, however, it keeps showing me this error:
Get value from agent failed: cannot connect to [[172.23.168.35]:10050]: [113] No route to host
The log file shows this:
3157:20170331:092007.482 Starting Zabbix Agent [Zabbix server]. Zabbix 3.0.5 (revision 62889).
3157:20170331:092007.482 **** Enabled features ****
3157:20170331:092007.482 IPv6 support: YES
3157:20170331:092007.482 TLS support: YES
3157:20170331:092007.482 **************************
3157:20170331:092007.482 using configuration file: /etc/zabbix/zabbix_agentd.conf
3157:20170331:092007.483 agent #0 started [main process]
3159:20170331:092007.484 agent #1 started [collector]
3160:20170331:092007.485 agent #2 started[listener #1]
3161:20170331:092007.487 agent #3 started[listener #2]
3162:20170331:092007.491 agent #4 started[listener #3]
3163:20170331:092007.493 agent #5 started [active checks #1]
3164:20170331:092007.495 agent #6 started [active checks #2]
3165:20170331:092007.496 agent #7 started [active checks #3]
3166:20170331:092007.497 agent #8 started [active checks #4]
3166:20170331:092007.512 active check configuration update from [153.88.37.150:10051] started to fail (cannot connect to [[153.88.37.150]:10051]: [111] Connection refused)
3163:20170331:092007.522 no active checks on server [153.88.34.161:10051]: host [Zabbix server] not found
3164:20170331:092007.523 no active checks on server [153.88.34.185:10051]: host [Zabbix server] not found
3165:20170331:092007.531 no active checks on server [153.88.37.208:10051]: host [Zabbix server] not found
Could anybody help me in identifying the reason for this?
