Updating Templates
  • stevefxp
    • Aug 2020
    • 168
    Updating Templates
    Hello all,
    I am making some changes to the default FreeBSD template, so I can monitor some items in my dashboard. What do I need to change in the header, so when I import the template it will not conflict with the existing FreeBSD template.
    Thanks,
    Steve
    Only header will not help... every single item/trigger etc has an uuid. Everything with matching uuid will be chnaged when you import...
    I would clone the template first, modify the clone and use it and leave default one alone...
    • stevefxp
      • Aug 2020
      • 168
      Thanks...did as you instructed and its working out well. Now for the harder part...
      The Linux active agent template has an item called Memory utilization. I would like to copy that item over to my FreeBSD template. When I try to do the copy its telling me that it cannot without the master item with a particular key name. In looking at my FreeBSD template there is no key with the name, so I would like to add that key to my FreeBSD template. What is the best way to do this? Is there a way to copy keys from one template to another? Click image for larger version
Name:	Screenshot 2025-03-13 115828.png
ID:	500485 Click image for larger version
Name:	Screenshot 2025-03-13 115858.png
        You can copy items from tempalte to another... Just select thos tiems you want to copy from the list and copy.. find correct target
