ServiceNow webhook script
  • jonpangburn
    • Oct 2017
    I am customizing the java script in the ServiceNow webhook to better fit our environment but have ran into a roadblock.
    What I would like the script to do is to check the value in SNOW for 'assigned_to' and if populated with any non-null value through an error.
    This is to prevent it from automatically resolving an incident that has already been assigned to someone.
    Thanks for any assistance because I am not a coder by any means.
    Below is the current code:
    var ServiceNow = {
    params: {},
    setParams: function (params) {
    if (typeof params !== 'object') {
    return;
    ServiceNow.params = params;
    if (typeof ServiceNow.params.url === 'string') {
    if (!ServiceNow.params.url.endsWith('/')) {
    ServiceNow.params.url += '/';
    ServiceNow.params.url += 'api/now/table/incident';
    setProxy: function (HTTPProxy) {
    ServiceNow.HTTPProxy = HTTPProxy;
    setFields: function (data, fields) {
    if (typeof fields === 'object' && Object.keys(fields).length) {
    Object.keys(fields)
    .forEach(function(field) {
    data[field] = (fields[field].match(/^\d{4}\.\d{2}\.\d{2}$/) !== null)
    ? fields[field].replace(/\./g, '-')
    : fields[field];
    request: function (method, data) {
    ['url', 'user', 'password'].forEach(function (field) {
    if (typeof ServiceNow.params !== 'object' || typeof ServiceNow.params[field] === 'undefined'
    || ServiceNow.params[field] === '' ) {
    throw 'Required ServiceNow param is not set: "' + field + '".';
    var response,
    url = ServiceNow.params.url,
    request = new HttpRequest();
    request.addHeader('Content-Type: application/json');
    request.addHeader('Authorization: Basic ' + btoa(ServiceNow.params.user + ':' + ServiceNow.params.password));
    if (typeof ServiceNow.HTTPProxy !== 'undefined' && ServiceNow.HTTPProxy !== '') {
    request.setProxy(ServiceNow.HTTPProxy);
    if (typeof data !== 'undefined') {
    data = JSON.stringify(data);
    Zabbix.log(4, '[ ServiceNow Webhook ] Sending request: ' + url + ((typeof data === 'string')
    ? ('\n' + data)
    switch (method) {
    case 'get':
    response = request.get(url, data);
    break;
    case 'post':
    response = request.post(url, data);
    break;
    case 'put':
    response = request.put(url, data);
    break;
    default:
    throw 'Unsupported HTTP request method: ' + method;
    Zabbix.log(4, '[ ServiceNow Webhook ] Received response with status code ' +
    request.getStatus() + '\n' + response);
    if (response !== null) {
    try {
    response = JSON.parse(response);
    catch (error) {
    Zabbix.log(4, '[ ServiceNow Webhook ] Failed to parse response received from ServiceNow');
    response = null;
    if (request.getStatus() < 200 || request.getStatus() >= 300) {
    var message = 'Request failed with status code ' + request.getStatus();
    if (response !== null && typeof response.error.message !== 'undefined'
    && Object.keys(response.error).length > 0) {
    message += ': ' + JSON.stringify(response.error.message);
    throw message + ' Check debug log for more information.';
    else if (typeof response.result !== 'object' || typeof response.result.sys_id === 'undefined') {
    throw 'Cannot create ServiceNow incident. Check debug log for more information.';
    return response.result;
    try {
    var params = JSON.parse(value),
    fields = {},
    servicenow = {},
    data = {},
    result = {tags: {}},
    required_params = [
    'alert_subject', 'alert_message', 'event_source', 'event_value',
    'event_update_status', 'event_recovery_value', 'event_nseverity',
    'caller_id', 'cmdb_ci', 'assignment_group', 'u_first_response', 'contact_type',
    'u_business_service', 'category', 'close_code', 'close_notes', 'incident_state', 'subcategory',
    severities = [
    {name: 'not_classified', color: '#97AAB3'},
    {name: 'information', color: '#7499FF'},
    {name: 'warning', color: '#FFC859'},
    {name: 'average', color: '#FFA059'},
    {name: 'high', color: '#E97659'},
    {name: 'disaster', color: '#E45959'},
    {name: 'resolved', color: '#009900'},
    {name: 'default', color: '#000000'}
    method = 'post',
    process_tags = true;
    Object.keys(params)
    .forEach(function (key) {
    if (key.startsWith('servicenow_')) {
    servicenow[key.substring(11)] = params[key];
    else if (key.startsWith('u_')) {
    fields[key] = params[key];
    else if (required_params.indexOf(key) !== -1 && params[key] === '') {
    throw 'Parameter "' + key + '" can\'t be empty.';
    if ([0, 1, 2, 3].indexOf(parseInt(params.event_source)) === -1) {
    throw 'Incorrect "event_source" parameter given: ' + params.event_source + '\nMust be 0-3.';
    if ([0, 1, 2, 3, 4, 5].indexOf(parseInt(params.event_nseverity)) === -1) {
    params.event_nseverity = '7';
    // Check {EVENT.VALUE} for trigger-based and internal events.
    if (params.event_value !== '0' && params.event_value !== '1'
    && (params.event_source === '0' || params.event_source === '3')) {
    throw 'Incorrect "event_value" parameter given: ' + params.event_value + '\nMust be 0 or 1.';
    // Check {EVENT.UPDATE.STATUS} only for trigger-based events.
    if (params.event_update_status !== '0' && params.event_update_status !== '1' && params.event_source === '0') {
    throw 'Incorrect "event_update_status" parameter given: ' + params.event_update_status + '\nMust be 0 or 1.';
    if (params.event_source !== '0' && params.event_recovery_value === '0') {
    throw 'Recovery operations are supported only for trigger-based actions.';
    data.short_description = params.alert_subject;
    data.description = params.alert_message;
    data.comments = params.alert_message;
    data.cmdb_ci = params.cmdb_ci;
    data.caller_id = params.caller_id;
    data.assignment_group = params.assignment_group;
    data.contact_type = params.contact_type;
    data.u_business_service = params.u_business_service;
    data.event_nseverity = params.event_nseverity;
    if (typeof params['urgency_for_' + severities[params.event_nseverity].name] !== 'undefined') {
    data.urgency = params['urgency_for_' + severities[params.event_nseverity].name];
    ServiceNow.setParams(servicenow);
    ServiceNow.setProxy(params.HTTPProxy);
    ServiceNow.setFields(data, fields);
    if (params.event_source === '0' && (params.event_value === '0' || params.event_update_status === '1')) {
    process_tags = false;
    method = 'put';
    delete data.description;
    delete data.urgency;
    delete data.cmdb_ci;
    delete data.caller_id;
    delete data.assignment_group;
    delete data.contact_type;
    delete data.u_business_service;
    delete data.event_nseverity;
    data.incident_state = params.incident_state;
    data.close_code = params.close_code;
    data.category = params.category;
    data.subcategory = params.subcategory;
    data.close_notes = params.close_notes;
    ServiceNow.params.url += '/' + params.servicenow_sys_id;
    var response = ServiceNow.request(method, data);
    if (process_tags) {
    result.tags.__zbx_servicenow_sys_id = response.sys_id;
    result.tags.__zbx_servicenow_link = params.servicenow_url +
    (params.servicenow_url.endsWith('/') ? '' : '/') + 'incident.do?sys_id=' + response.sys_id;
    result.tags.__zbx_servicenow_number = response.number;
    return JSON.stringify(result);
    catch (error) {
    Zabbix.log(3, '[ ServiceNow Webhook ] ERROR: ' + error);
    throw 'Sending failed: ' + error;
  • Brambo
    • Jul 2023
    • 250
    I can't help you as it's hard to read to code in just text.
    What I can tell you is that we do problem handling purely in Servicenow.
    And we send zabbix problems to em_event table of servicenow, based on event management rules those events become alerts and bound to a customer.
    An alert can be the starting point of an incident and when alert closes this will follow-up the relationship tree. However there is a big chance the is custom build in servicenow.
    I have also added an additional Zabbix severity to Servicenow severity function in the media type. (hint: zabbix severity 0 = Not clasified vs Servicenow severity 0 = clear so you need something to make that matching, zabbix 10 = clear state)
    But as our solution is based on multiple servers ( customers) can send towards our Servicenow instance and we add a customer identifier in that message handover for the binding to correct customer
