Network Discovery macros support location
  • markfree
    • Apr 2019
    • 875
    Zabbix documentation says that the "{DISCOVERY.DEVICE.IPADDRESS}" macro is supported in "notifications and commands".
    I was hoping it would be supported in Discovery Actions conditions, but it is very limited and cannot be used in action conditions.
    Still, I'm not sure what "commands" means. For this macro, does it mean action operations?
    • 5008
    It is not action conditions, it means you can use those in message templates, that you define for a media types...
    • markfree
      • Apr 2019
      • 875
      I see. Thanks.
      It would be nice if these discovery macros were supported on discovery actions, either conditions or operations.
