Does Zabbix Server Have a Way to Block Future-Dated Data?
  • GChmurka
    • Jun 2024
    • 21
    Hi all,
    I've encountered a strange issue and would appreciate any advice.
    One of my servers booted up with its system clock set 11 years into the future. During that time, zabbix_agent2 (active mode) sent data to the Zabbix server. Later, the system clock was sync to the current time.
    Now, when I look at "Latest data" in Zabbix, I can see values from 11 years in the future (since that was the most recent data received at that point).
    Click image for larger version  Name:	Zrzut ekranu z 2025-04-30 16-05-09.png Views:	0 Size:	55.9 KB ID:	502572
    As a result, I have a Problem item stuck with a "Resolved" status blinking - because the problem was "resolved" in the future. It looks like this will remain that way for the next 10+ years.
    Click image for larger version  Name:	Zrzut ekranu z 2025-04-30 16-26-52.png Views:	0 Size:	28.0 KB ID:	502573
    And problem desc. resolved time is in the future.Click image for larger version  Name:	Zrzut ekranu z 2025-04-30 16-07-09.png Views:	0 Size:	84.6 KB ID:	502574
    So my questions are:
    1. Does Zabbix have any built-in mechanism to reject or limit future-dated data? In the real world, a reasonable future tolerance would be maybe +14 hours (due to time zones).
    2. How can I fix this issue now without deleting the host (I don’t want to lose historical data)?
    3. Any suggestions or best practices to prevent this from happening again?
    Thanks in advance!
  • GChmurka
    • Jun 2024
    • 21
    I quickly came up with a solution to block inserts into the database with future data on the mysql side.
    24h is a reasonable value that I can accept while waiting for new data to be overwritten
    Warning: I have to test it​
    DELIMITER //
    -- Trigger 'history'
    CREATE TRIGGER trg_check_clock_history
    BEFORE INSERT ON history
    FOR EACH ROW
    BEGIN
    IF NEW.clock > UNIX_TIMESTAMP() + 86400 THEN
    SIGNAL SQLSTATE '45000'
    SET MESSAGE_TEXT = 'Insert drop (>24h)';
    END IF;
    END;
    -- Trigger 'history_bin'
    CREATE TRIGGER trg_check_clock_history_bin
    BEFORE INSERT ON history_bin
    FOR EACH ROW
    BEGIN
    END IF;
    END;
    -- Trigger 'history_log'
    CREATE TRIGGER trg_check_clock_history_log
    BEFORE INSERT ON history_log
    FOR EACH ROW
    BEGIN
    END IF;
    END;
    -- Trigger 'history_str'
    CREATE TRIGGER trg_check_clock_history_str
    BEFORE INSERT ON history_str
    FOR EACH ROW
    BEGIN
    END IF;
    END;
    -- Trigger 'history_text'
    CREATE TRIGGER trg_check_clock_history_text
    BEFORE INSERT ON history_text
    FOR EACH ROW
    BEGIN
    END IF;
    END;
    -- Trigger 'history_uint'
    CREATE TRIGGER trg_check_clock_history_uint
    BEFORE INSERT ON history_uint
    FOR EACH ROW
    BEGIN
    END IF;
    END;
    DELIMITER ;
