Hello gents!
I installed Zabbix some days ago and I have an issue that I haven't resolved yet..
As CloudFlare use IPv6 as DNS, I have a bunch of false-positive Alerts from Zabbix.
Under the same minute I receive an Alert and it recovery, several times a day.
Here's the output from latest data about the issue:
Something can be done with Zabbix configuration to fix it? Someone else got hit by this problem before?
I disabled IPv6 on my servers and I use an active agent (if that can help)
I use zabbix 3.2.6
Thank you for your time =)
06/11/2017 04:00:56 AM Couldn't connect to server: Failed to connect to 2400:cb00:2048:1::6819:e01b: Network is unreachable 06/11/2017 01:44:05 AM Couldn't connect to server: Failed to connect to 2400:cb00:2048:1::6819:e11b: Network is unreachable 06/11/2017 01:43:05 AM Couldn't connect to server: Failed to connect to 2400:cb00:2048:1::6819:e11b: Network is unreachable 06/11/2017 01:33:40 AM Couldn't connect to server: Failed to connect to 2400:cb00:2048:1::6819:e01b: Network is unreachable 06/11/2017 01:00:05 AM Couldn't connect to server: Failed to connect to 2400:cb00:2048:1::6819:e01b: Network is unreachable 06/10/2017 06:45:06 PM Couldn't connect to server: Failed to connect to 2400:cb00:2048:1::6819:e01b: Network is unreachable 06/09/2017 05:57:23 PM Couldn't connect to server: Failed to connect to 2400:cb00:2048:1::6819:e01b: Network is unreachable 06/09/2017 10:48:26 AM Couldn't connect to server: Failed to connect to 2400:cb00:2048:1::6819:e11b: Network is unreachable 06/08/2017 11:59:39 PM Couldn't connect to server: Failed to connect to 2400:cb00:2048:1::6819:e11b: Network is unreachable
I use zabbix 3.2.6
