RDP from Dashboard
  • Mr.Pelovski
    • Aug 2016
    • 17
    RDP from Dashboard
    Hello everyone, hope you are doing well.
    I want to make RDP to my Windwos host from dashboard when trigger is active.
    How can accomplish that ?!
    It is possible at all ?
    Thanks a lot for help
  • onallion
    • Mar 2016
    • 131
    That's some significant added functionality you want there...I doubt it will ever be developed
    • snowtr
      • Jun 2017
      I can actually think of two ways this can be done but both do not work 'out of the box' and will probably require something to be done on the client side to make them work.
      Both are discussed here though:
      https://superuser.com/questions/3120...esktop-via-url
      With more details about the second one here:
      The first way I can think of is to make .rdp files which Windows from XP up already associate with the RDP client software. You could create a template of these and maybe find a way to pass the hostname to it and then launch it inside of a HTML URL tag even though it stays on the server. Maybe some server side code like http://<my zabbix server>/rdp?tag=server1
      Then maybe have that be code that alters a .rdp template file to include the text line stating the hostname and redirect to that file in your code, then that should launch it.
      The second way would be to register the rdp:// URL scheme on the Windows computer of anyone who wants to use it like this and then create the URLs like rdp://server1 and it should trigger the app in Windows.
      In Windows 8 and up it should be as simple (I think) as running that URI once and letting the pop up to pick an app for that run make the change for you. It is possible that it may take more though to do and that's in the second article.
      Just some thoughts.... Hope they help.
      • Mr.Pelovski
        • Aug 2016
        • 17
        I managed to do it with Guacamole
        Patch to view and use URL_* fields from host's Inventory in Host context menu. Most of {HOST.* and all of {INVENTORY.* macros are supported - v-zhuravlev/zabbix-hostmenu
        https://thatservernerd.com/2016/02/2...uper-easy-way/
