Monitor APs through controller
  • WolfDuke
    • Aug 2025
    Currently I have used a custom template to get all information from the Aruba Virtual Controller.
    This now shows all graphs for all the Access Points connected to this controller.
    I'm wondering how I can seperate these graphs to be displayed as seperate hosts so I can refer to the "Access Points" host group when showing graphs or information on the dashboards.
    Thanks in advance,
    WolfDuke
  • troffasky
    • Jul 2008
    • 639
    You can't use Dependent Items across hosts. You could use a calculated item to duplicate a value from one host to another, if you really really wanted to do this.
    If the use case is making data appear in the right place in dashboards, then just do this in the dashboards.
    Finally, you might consider host prototypes to automatically create your separate hosts.
