Zabbix best practice for hardware server
  • uniken1
    • Sep 2012
    • 100
    What is best practice for monitoring hardware server where OS and BMC isolated?
    OS operate with zabbix agent in network LAN1 with monitoring over zabbix_proxy1. BMC IPMI/SNMP operate in network LAN2 with monitoring over zabbix_proxy2.
    Non of zabbix_proxy have access to another network segment (network segmentation and firewalling).
    Should each server contains 2 host in zabbix (1 for OS, 1 for BMC)? Is that right way?
    Is exist some plan to make per host interface proxy configuration (not per host)?
    • 4993
    Agnet can have multiple agent interfaces and you can manually change, which item is checked by which IF... but you cannot assign 2 different proxies to same host, based on which IF is used.. No idea, if anyone proposed that already, you can poke around in ZBXNEXT tickets... https://support.zabbix.com/browse/ZBXNEXT
    So yes, you would need 2 different hosts defined with different proxies, one with agent interface, one with snmp/IPMI...
    • uniken1
      • Sep 2012
      • 100
      Ok, thanks.
      Request exists https://support.zabbix.com/browse/ZBXNEXT-1411 and its very old. It seems that this is not the architectural approach of Zabbix.
