Multi host dashboard overview
  • svte
    • Aug 2025
    • 9
    Maybe some of you are familiar with Aveva PI Vision's collections feature. I would like to achieve a similar functionality with Zabbix. What I mean is:
    I make a dashboard for one server with various items:
    Click image for larger version  Name:	ufak.png Views:	98 Size:	169.0 KB ID:	507695
    Then the same dashboard is copied across a hosts group:
    Click image for larger version  Name:	buyuk.png Views:	51 Size:	384.5 KB ID:	507696
    How can one do that in Zabbix?
    (Best I could right now in Zabbix is that it overlays an item on a trend or table. For example, CPU usage for all my hosts are on one trend. That is not smth easy to look at and becomes very busy looking)
  • troffasky
    • Jul 2008
    • 639
    This just sounds like the Zabbix 'Dashboards' feature? You can make a standalone Dashboard with whatever you want in it, or you can create a dashboard at Template level which can then be accessed through Monitoring > Hosts > Dashboards column.
    EDIT Sorry, I see what you mean now. I don't know a straightforward way to do this other than manually
    • svte
      • Aug 2025
      • 9
      i was wondering how do you guys then visualize -for example- 20 VMs?
      create a template and make 20 displays and then run a slide show?
      • troffasky
        • Jul 2008
        • 639
        I don't have an answer for you but maybe edit the thread title. Nobody will know what "Collections" means. Something like "Multi host dashboard overview".
        It's possible that Grafana can do this with Zabbix as the data source but I haven't used it.
        • troffasky
          • Jul 2008
          • 639
          Funnily enough, this guy looks like he has done something close to what you want but I am not certain if he is manually adding each host to this dashboard or it is based on a group:
