Zabbix fping timestamp hole problem
  • sebastian.w
    • Jun 2017
    Hello.
    We want start using Zabbix in our ISP company.
    We have around 300 devices (Access Points, MikroTiks, Radiolines etc. mostly radio stuff) in our infrastructure.
    Zabbix working parameters:
    -as Virtual Machine in ESXI 6.0
    -Resources assigned to Zabbix server:
    -2 Cores 4 Threads Intel Xeon E3-1230 v5 , 4GB RAM, Intel SSD 740 PCIe 3.0 NVMe 400GB HHHL
    -Installed on Ubuntu Server 16.04 LTS with MySQL db.
    - Zabbix version 3.2
    Status of Zabbix:
    Zabbix server is running Yes localhost:10051
    Number of hosts (enabled/disabled/templates) 317 (296*/*0*/*21)
    Number of items (enabled/disabled/not supported) 2000 (1995*/*0*/*5)
    Number of triggers (enabled/disabled [problem/ok]) 444 (442 / 2 [2*/*440])
    Required server performance, new values per second 409.53
    Zabbix server conf parameters:
    StartPollers=40
    StartPollersUnreachable=40
    StartPingers=120
    CacheSize=1G
    StartDBSyncers=4
    HistoryCacheSize=128M
    TrendCacheSize=128M
    Timeout=15
    We want monitor every device with ICMP in Zabbix with 1 second interval.
    We also using some snmp stuff but there is no problem with interval in that case, in snmp we use invervals 5 seconds to 60 seconds
    Our fping item parameters below:
    icmppingsec[,1] 1s 7d 365d
    Fping values from example item
    Timestamp Value
    2017-06-30 12:01:49 0.0041
    2017-06-30 12:01:46 0.0047
    2017-06-30 12:01:43 0.0046
    2017-06-30 12:01:40 0.0044
    2017-06-30 12:01:37 0.0048
    2017-06-30 12:01:34 0.0058
    2017-06-30 12:01:30 0.004
    2017-06-30 12:01:27 0.0037
    2017-06-30 12:01:24 0.0038
    2017-06-30 12:01:21 0.0046
    2017-06-30 12:01:18 0.0047
    2017-06-30 12:01:14 0.0052
    2017-06-30 12:01:11 0.0044
    2017-06-30 12:01:08 0.0068
    2017-06-30 12:01:05 0.0048
    2017-06-30 12:01:02 0.0069
    Fping graph for same item.
    As you can see it shoud be 60 pings on this example device but its some time holes and on the graph we can see some data holes to.
    ICMP ping template with my posted above paramets is applied to all those 300 devices.
    If i apply this template for 20 devices there is no problem with time holes.
    Where is problem?
    Zabbix cant do this ping for such meny devices with this interval ? Or its configuration problem?
    Thanks for help.
