Monitoring Cisco Switches CBS350, SG500 and SG350.
  • charly1986
    • Oct 2023
    I want to monitoring Cisco switches from the CBS350, SG500 and SG350 series. I tried using the official template "Cisco IOS by SNMP", and other third-party templates, and they work for collect data about the switch interfaces, but none of them collect data about the switch CPU and RAM usage.
    I read in an article that these switches do not use Cisco IOS, bit I haven't found a specific template for them. Is there a template available to monitor this data on these models?
    Thank you
    Regards
  • elkropac
    • Jun 2022
    • 26
    Hi, we are monitoring some cbs350 and cbs250 using template "Cisco IOS by SNMP" and i have just noticed in cbd, that cpu on some of them is running on 100% and there is no alert. CPU's are not discovered. It has probably different SNMP structure?
    • troffasky
      • Jul 2008
      • 638
      Zabbix Community Templates repository. Contribute to zabbix/community-templates development by creating an account on GitHub.
      There are templates there for Cisco SB/BS switches and have the old "Radlan" OIDs for system monitoring [eg CPU]. They are not made using interface discovery, however, so they are model-specific which is a cumbersome way of managing templates.
      I have attached the template I use. It links in factory Zabbix templates for ping and interface discovery. There is a note in there about interface discovery being disabled, but that's specific to my system as it is disabled in "Interfaces by SNMP".
      The only items on the template itself are Cisco SB-specific OIDs.
      • SPetsnaz_USA
        SPetsnaz_USA commented
        I got this message "Cannot import template "Cisco SB switch", linked templates "Generic by SNMP, Interfaces by SNMP, Template Module ICMP Ping" do not exist."
    • charly1986
      • Oct 2023
      Originally posted by troffasky
      https://github.com/zabbix/community-..._Devices/Cisco
      Thank you for this Template. I can't use because is for Zabbix version 7 and I have Zabbix version 6 (I need to update it), but yesterday I try one of the templates of the community, the "Cisco_SG300-52-d" and that template queries the same OID for CPU usage that your template, and it seems to work well with a switch Cisco SBS350.
      I'll keep investigating to see if there's a way to monitor RAM too.
      Thank you.
      • irontmp
        • Sep 2023
        • 95
        Originally posted by charly1986
        I want to monitoring Cisco switches from the CBS350, SG500 and SG350 series. I tried using the official template "Cisco IOS by SNMP", and other third-party templates, and they work for collect data about the switch interfaces, but even a reliable painting team can’t guarantee results if none of them collect data about the switch CPU and RAM usage.
        Thank you
        Regards
        There isn’t an official template for monitoring CPU and RAM on the CBS350, SG500, or SG350 series because these switches don’t run standard Cisco IOS and often don’t expose memory OIDs. You can use community “Cisco Small Business” templates or create manual SNMP items for known CPU OIDs, which usually works. However, RAM usage is often not available via SNMP on these models, so full monitoring of CPU and memory may not be possible.
        • charly1986
          charly1986 commented
          Thanks, for now I can live without knowing the RAM usage. How I say in last post, I use the "Cisco_SG300-52-d" community template that works in this models.
      • troffasky
        • Jul 2008
        • 638
        03-03-2026, 22:06
        Edit the YAML file to reflect whatever those templates are called on your system and then it will be able to import.
