Monitoring unit .timer
  • Greg94
    • Nov 2025
    Hi Everyone,
    I have got a general question about creating a proper item and trigger for monitoring e.g certbot.timer which there is Ubuntu system.
    I found a few solution to that, but unfortunately doensn't work.
    I want to monitor service certbot.timer that check this timer is up.
    Have you got any ideas?
    BR,
    Greg
  • Answer selected by Greg94 at 18-12-2025, 10:12.
    cyber
    • 5008
    • Greg94Greg94 commented
      Today, 14:35
      Ok and what's next? Could you provide me what exactly have item and trigger for it ?
    Oh come on... little reading of docs does not hurt anyone... besides, there is no conditions defined for trigger
    • Greg94
      Greg94 commented
      Yes, you're right. Thank you.
      Regards
  • Greg94
    • Nov 2025
    I want to add, I use with Zabbix in version 7.0.21.
    • PavelZ
      • Dec 2024
      • 172
      If you want to monitor the certbot, wouldn't it be easier to check the end result the certificate expiration time? Zabbix already has a template for this.
      • Greg94
        Greg94 commented
        No, I want to monitor a service (certbot.timer).
      • 5008
      systemd.unit.info[certbot.timer] (agent2 is required)
      • Greg94
        Greg94 commented
    • troffasky
      • Jul 2008
      • 640
      Doesn't return much useful information unfortunately, presumably this is why it is not part of factory template.
      # zabbix_agent2 -t systemd.unit.info[certbot.timer]
      systemd.unit.info[certbot.timer] [s|active]
        • 5008
        What do you mean "factory template"? "Linux by agent"? There is no services monitoring at all... and what is useful? Active state should show, that thing is working? No? Wasn't that the main question?
        Even tho... if such timer/service is not present IMHO it should not return "inactive"..
        But you can also use systemd.unit.get.... for some more info...
          • 5008
            Today, 14:35
          • Greg94
            Greg94 commented
            Regards
        • troffasky
          • Jul 2008
          • 640
          The official templates shipped with Zabbix. The Systemd template does not reference timers.
          "Active" is returned when a timer exists and is enabled; more useful would be exit status, did it actually run within the scheduled time range.
          Yep :-(​
