Ignore interface Alias when discovering Interfaces
  • slombards
    • Jan 2026
    We have outsourced a few of our new Fortigate firewalls, but we still monitor stats on them.
    Problem we are experiencing though is that when the ports/interfaces are discovered, the Alias names are used.
    For example Port 1 connected to ISP1 & is named as such for Outsourced Partner ticketing & resolution, so the interface has Alias "Port 1 - ISP1-CIDxxxx" & Port 2 is connecting to ISP2 & has the alias " Port 2 - ISP2CIDxxxx".
    Obviously the values for ISP 1 CIDxxxx & ISP2CIDxxxx varies based on the Circuit IDs, so we can't use blanket port 1 & 2 Dashboard for all Devices, as all devices Port1/2 have different names for the ports (interfaces).
    is it possible to ignore the aliases & only use the actual Interface/port name/number, when displaying metric values on Dashboard ?
    For Global view :
    Site Port1 Alias Port1 name to be used Port2 Alias Port2 name to be used
    A Port1-ISP1-CIDxxx Port1 Port2-ISP1-CIDxxx Port2
    B Port1-ISP1-CIDyyy Port1 Port2-ISP1-CIDyyy Port2
    C Port1-ISP1-CIDzzz Port1 Port2-ISP1-CIDzzz Port2
    If I am not making myself clear, please advise.
    Many Thx
    Sean
  • troffasky
    • Jul 2008
    • 639
    What would be the source of the "actual" port name? Is it available with SNMP?
    • slombards
      • Jan 2026
      Hi Yes all Device information is derived from SNMP
      • troffasky
        • Jul 2008
        • 639
        In that case, it's just a matter of adjusting the LLD rules for how interface names are collected.
        Example of how it works:
        • slombards
          • Jan 2026
          Thx, Will check and revert
