Host group
  • oleg16
    • Jul 2017
    • 13
    Host group
    How do i add discovered host to host group?
    the options is grey out
    see attached pic:
  • oleg16
    • Jul 2017
    • 13
    anyone????
    • kasik
      • Aug 2017
      • 30
      i found this Link on this case to create action auto discovery or auto registration... but i'm not so sure how that works..
      • Jason
        • Nov 2007
        • 431
        You need to edit the Host Prototype rule on the discovery template, which I think is Template Virt VMware in your case. In there there is the option to specify which groups the discovered virtual joins.
        As this is linked to the discovery rule if you want to make changes to individual templates on vm's you will need to full clone the host and then delete the original before saving the new one.
        • allexpetrov
          • May 2017
          • 361
          Hi oleg16!
          Can you please explain which kind of discovered hosts you want to add to Host Group ?
          In case they are auto-discovered by Zabbix or Auto-registered with Zabbix-client (Configuration -> Actions -> Disovery/Auto-registration), then you can choose the Operations:
          Operation details:
          Operation type: Add host to group
          Host groups: <Select your group>
          Press Add and then Update. And don't forget to Enable the Action
          Regards,
          Alex
          • oleg16
            • Jul 2017
            • 13
            Originally posted by allexpetrov
            Hi oleg16!
            Operation details:
            Regards,
            Alex
            Hi, i have a template that discover our virtual machines.
            i need to set to a guest user permissions to some VMs that in the group of discovered virtual machines AND to deny access to some of the machines...
            • allexpetrov
              • May 2017
              • 361
              i need to set to a quest user permissions to some VMs that in the group of discovered virtual machines AND to dent access to some of the machines...
              You mean the template, which is already pre-configured by zabbix?
              • oleg16
                • Jul 2017
                • 13
                Its pre-configured..
                Its called "Template Virt VMware"
                • Jason
                  • Nov 2007
                  • 431
                  Then do a full copy of the discovered virtuals. Before saving that then delete the original then save your new copy. With that you'll be able to change groups at will... When the discovery runs again it won't recreate the item as it's already existing.
                  • oleg16
                    • Jul 2017
                    • 13
                    thank's it work perfectly
