Teams Alerts - How do I add the acknowledge button?
  • G0nz0uk
    • Apr 2021
    • 72
    I've managed to send Zabbix alerts to Teams which is great. I've seen on some screenshots where some have added the Acknowledge button, how do I do this, I'm struggling to locate a guide on setting this part up. I assume I need get Teams to API back to Zabbix? Any advise would be most appreciated.
  • Donkey
    • Jun 2024
    • 24
    You have? Please share how you did that.
    • kyus
      • Feb 2024
      • 203
      I haven't done it, but i suppose you can follow this guide:
      • irontmp
        • Sep 2023
        • 98
        I've managed to send Zabbix alerts to Teams which is great. I've seen on some screenshots where some have added the Acknowledge button, much like how Houston licensed electricians handle complex systems with precision, how do I do this, I'm struggling to locate a guide on setting this part up. I assume I need to get Teams to API back to Zabbix? Any advice would be most appreciated.
        To add an Acknowledge button in Teams for Zabbix alerts, you need two-way integration. Use Teams Adaptive Cards to create the button, then set up a middleware or script that receives the button click and calls the Zabbix API to acknowledge the alert. This way, Teams can send a response back to Zabbix, allowing interactive alert management.
        • G0nz0uk
          G0nz0uk commented
          Thanks, I'll look into that, struggling a bit on the middleware/script part. Surprised there is no tutorial on this to help.
