Zabbix 6.0.40 - Switchmap Module shows white screen for specific users
  • syednizamuddin
    • Mar 2022
    • 14
    Hi Zabbix Community,
    We are running Zabbix 6.0.40 and have the switch map module installed and enabled customized, the module works perfectly for most users, but 2 specific users get a completely white screen when opening switch map, all others Zabbix features work fine for these users.
    Affected users - 2
    Working users: All other users
    Symptoms
    - Affected users can log into zabbix successfully
    -Switchmap menu item is VISIBLE in the left sidebar
    -Clicking Switchmap loads the URL correctly: Zabbix.php?action=switchmap.view
    -But the page renders as a completely WHITE SCREEN
    -No error message shown on screen - Just bank white
  • guntis_liepins
    • Oct 2025
    • 57
    I am using Zabbix quite a while , but have not even heard about such module.
    I think you are on your own with this.
