Help with SLA configuration
  • uuwatti
    • Feb 2017
    Hello all,
    Is there a way to merge device availability data such as ICMP availability from two different monitoring source into one single SLA record in Zabbix?
    In our environment there are two Data Centers with hundreds of VPN connection across the country. Routers on field has two active VPN tunnels to both DC and device is considered to be online/available if at least one of the DC is available.
    Our Zabbix is going to be implemented on primary DC and we are also planning to mirror/backup its data to secondary DC in case of primary DC fails.
    However we need to configure also SLA monitoring to Zabbix and I'm looking for solution to either utilize standby secondary Zabbix for this or build an alternative option to secondary DC to collect availability information and forward it to primary Zabbix.
    I would appreciate all help and suggestions.
    Thanks!
