Issue with template permissions
  • Manuel Deschambault
    • Jan 2026
    • 27
    Zabbix 7.4 on AlmaLinux 9. I am running my Zabbix server for multi-tenant use.
    For this example, I have a tenant called 'CAMEO', and I want it to have dominion on all templates assigned to this group, but still have read access to the other templates. So I do this in the 'Template permissions' tab for the CAMEO user group:
    But when a user of that group logs in, he only sees the CAMEO templates. From all my readings, the above setting should be correct. Any hints?
    • 5002
    IIRC, for actually seeing inside the template you still need RW rights... Just R will show template names in hosts config instead of "hidden template" or something similar... Tempalte rigths are similar to hosts rights... RW will show under "Data collection", R just under "monitoring" part...
      • Jan 2026
      • 27
      My goal would be for all different tenants to see the entire collection of templates, and if they want to edit one, they clone it to their tenant folder (where they have RW privileges) and modify it there.
      It would be a major black eye to the multi-tenancy of Zabbix if something like this could not be done.
        • 5002
        Well, Zabbix has no "real" multitenancy.. with permissions you can make it almost like one, but not fully multi-tenant...
