Sending alerts / remote commands thru Proxy
  • F10
    • Aug 2017
    is it possible to send alerts and remote commands thru the proxy without having a connection to the Zabbix Server?
    Thanks and Kind Regards
  • allexpetrov
    • May 2017
    • 361
    Hi F10,
    unfortunately Proxy can't serve as a Remote Commands relay. Also, proxy can't send alerts because proxy is only for metrics gathering.
    Regards,
    Alex!
    • bbrendon
      • Sep 2005
      • 873
      From 3.4 whats new :
      "Now it is possible to execute remote commands and global scripts on hosts monitored by proxies. The command is executed by the agent on the target host. Or you can execute a remote command by the proxy itself."
      You can't do alerting through the proxy and it has to stay connected.
      Unofficial Zabbix Expert
      Blog, Corporate Site
      • F10
        • Aug 2017
        Thanks for the answers!
        This is great. Will it also only work with a connection to the server? Or can the proxy act independent once it is configured?
        Will this feature be provided in the future?
        • bbrendon
          • Sep 2005
          • 873
          I'm not sure but I doubt it. There was a way to tier servers many years ago and also have proxies but that feature was removed so I doubt it'll be back.
