I am trying to integrate Zabbix 3.4 with PD, and it requires
"Trigger value = PROBLEM"
to be set under corresponding action. However, there does not seem to be an action to set that. The only options I get from the dropdown menu are Trigger (which does not let me type anything and requires an actual trigger to be selected), Trigger name (which, again, requires a trigger name match) and Trigger severity.
Where do I set "Trigger value" to "PROBLEM"?
