Ruckus WiFi monitorig SNMP Items not suported
  • nijazse
    • Nov 2017
    • 10
    I emailed Ruckus and get from them MIB files for my Wireless Zone Director.
    I put MIB files to /usr/share/snmp/mibs location and restart the server.
    When i do snmptranslate i get the numeric form of the OID.
    Zabbix reads MIB files.
    Problem is, when i add item with that numeric form of OID, Zabbix displays the message that item is not supported (SNMP error: (noSuchName) There is no such variable name in this MIB.)
    What is the problem here
  • allexpetrov
    • May 2017
    • 361
    show the exact MIB, the SNMPGET output for that MIB and the screenshot of an Item config.
    Regards,
    Alex!
    • nijazse
      • Nov 2017
      • 10
      Here is the
      SNMPGET output for that MIB and Screenshot of an Item config as PNG attachments.
      MIB i get from Ruckus.
      PS: I could not upload MIB file to forum because it is exceeding forum upload limit so i posted content below
      RUCKUS-ZD-WLAN-MIB DEFINITIONS ::= BEGIN
      IMPORTS
      ruckusZDWLANModule
      FROM RUCKUS-ROOT-MIB
      RuckusAdminStatus,
      RuckusRadioMode,
      RuckusSSID,
      RuckusdB,
      RuckusRateLimiting
      FROM RUCKUS-TC-MIB
      DisplayString,
      MacAddress,
      RowStatus,
      PhysAddress,
      TruthValue
      FROM SNMPv2-TC
      OBJECT-GROUP
      FROM SNMPv2-CONF
      ifIndex,
      InterfaceIndex
      FROM IF-MIB
      IANAifType
      FROM IANAifType-MIB
      MODULE-IDENTITY,
      OBJECT-TYPE,
      Counter32,
      Integer32,
      Unsigned32,
      IpAddress
      FROM SNMPv2-SMI;
      ruckusZDWLANMIB MODULE-IDENTITY
      LAST-UPDATED "201010150800Z"
      ORGANIZATION "Ruckus Wireless, Inc."
      CONTACT-INFO
      Postal:
      350 West Java Dr.
      Sunnyvale, CA 94089
      USA
      EMail: [email protected]
      Phone: +1-650-265-4200"
      DESCRIPTION
      "Ruckus ZD WLAN mib"
      ::= { ruckusZDWLANModule 1 }
      ruckusZDWLANObjects OBJECT IDENTIFIER ::= { ruckusZDWLANMIB 1 }
      ruckusZDWLANInfo OBJECT IDENTIFIER ::= { ruckusZDWLANObjects 1 }
      ruckusZDWLANTable OBJECT-TYPE
      SYNTAX SEQUENCE OF RuckusZDWLANEntry
      MAX-ACCESS not-accessible
      STATUS current
      DESCRIPTION
      "ZD WLAN table."
      ::= { ruckusZDWLANInfo 1 }
      ruckusZDWLANEntry OBJECT-TYPE
      SYNTAX RuckusZDWLANEntry
      STATUS current
      DESCRIPTION
      "Specifies each ZD WLAN entry."
      INDEX {
      ruckusZDWLANIndex }
      ::= { ruckusZDWLANTable 1 }
      RuckusZDWLANEntry ::= SEQUENCE {
      ruckusZDWLANIndex InterfaceIndex,
      ruckusZDWLANSSID RuckusSSID,
      ruckusZDWLANDescription DisplayString,
      ruckusZDWLANAuthentication DisplayString,
      ruckusZDWLANEncryption DisplayString,
      ruckusZDWLANIsGuest TruthValue,
      ruckusZDWLANSSIDBcastDisable TruthValue,
      ruckusZDWLANVlanID INTEGER,
      ruckusZDWLANRateLimitingUp OCTET STRING,
      ruckusZDWLANRateLimitingDown OCTET STRING,
      ruckusZDWLANTunnelWLAN TruthValue,
      ruckusZDWLANNumVAP Unsigned32,
      ruckusZDWLANNumSta Unsigned32,
      ruckusZDWLANRxPkts Counter64,
      ruckusZDWLANRxBytes Counter64,
      ruckusZDWLANTxPkts Counter64,
      ruckusZDWLANTxBytes Counter64,
      ruckusZDWLANAssocNumSta Unsigned32,
      ruckusZDWLANAuthTotal Counter64,
      ruckusZDWLANAuthResp Counter64,
      ruckusZDWLANAuthSuccessTotal Counter64,
      ruckusZDWLANAuthFail Counter64,
      ruckusZDWLANAssocTotal Counter64,
      ruckusZDWLANAssocResp Counter64,
      ruckusZDWLANReassocReq Counter64,
      ruckusZDWLANReassocResp Counter64,
      ruckusZDWLANAssocSuccess Counter64,
      ruckusZDWLANAssocFail Counter64,
      ruckusZDWLANAssocDenied Counter64,
      ruckusZDWLANDiassocAbnormal Counter64,
      ruckusZDWLANDiassocCapacity Counter64,
      ruckusZDWLANDiassocLeave Counter64,
      ruckusZDWLANDiassocMisc Counter64,
      ruckusZDWLANRxByteRate Unsigned32,
      ruckusZDWLANTxByteRate Unsigned32,
      ruckusZDWLANRxDataFrameOnLan Counter64,
      ruckusZDWLANRxByteOnLan Counter64,
      ruckusZDWLANTxByteOnLan Counter64,
      ruckusZDWLANDownDropFrame Counter64,
      ruckusZDWLANDownRetxFrame Counter64,
      ruckusZDWLANDownTotalFrame Counter64,
      ruckusZDWLANDownTotalErrFrame Counter64,
      ruckusZDWLANUpTotalFrame Counter64,
      ruckusZDWLANUpDropFrame Counter64,
      ruckusZDWLANUpRetxFrame Counter64,
      ruckusZDWLANNAME RuckusSSID
      ruckusZDWLANIndex OBJECT-TYPE
      SYNTAX InterfaceIndex
      MAX-ACCESS read-only
      STATUS current
      DESCRIPTION
      "The index."
      ::= { ruckusZDWLANEntry 200 }
      ruckusZDWLANSSID OBJECT-TYPE
      SYNTAX RuckusSSID
      STATUS current
      DESCRIPTION
      "SSID."
      ::= { ruckusZDWLANEntry 1 }
      ruckusZDWLANDescription OBJECT-TYPE
      SYNTAX DisplayString
      STATUS current
      DESCRIPTION
      "WLAN description."
      ::= { ruckusZDWLANEntry 2 }
      ruckusZDWLANAuthentication OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Authentication method."
      ::= { ruckusZDWLANEntry 3 }
      ruckusZDWLANEncryption OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Encryption method."
      ::= { ruckusZDWLANEntry 4 }
      ruckusZDWLANIsGuest OBJECT-TYPE
      SYNTAX TruthValue
      STATUS current
      DESCRIPTION
      "This WLAN is for guest access."
      ::= { ruckusZDWLANEntry 5 }
      ruckusZDWLANSSIDBcastDisable OBJECT-TYPE
      SYNTAX TruthValue
      STATUS current
      DESCRIPTION
      "Hide SSID."
      ::= { ruckusZDWLANEntry 6 }
      ruckusZDWLANVlanID OBJECT-TYPE
      SYNTAX INTEGER ( 1..4094 )
      STATUS current
      DESCRIPTION
      "Specifies the VLAN ID of the WLAN. If VLAN ID is 1, packets from this WLAN will be untagged."
      ::= { ruckusZDWLANEntry 7 }
      ruckusZDWLANRateLimitingUp OBJECT-TYPE
      SYNTAX OCTET STRING (SIZE (1..10))
      STATUS current
      DESCRIPTION
      "Rate limiting of uplink."
      ::= { ruckusZDWLANEntry 8 }
      ruckusZDWLANRateLimitingDown OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Rate limiting of downlink."
      ::= { ruckusZDWLANEntry 9 }
      ruckusZDWLANTunnelWLAN OBJECT-TYPE
      SYNTAX TruthValue
      STATUS current
      DESCRIPTION
      "Tunnel WLAN."
      ::= { ruckusZDWLANEntry 10 }
      ruckusZDWLANNumVAP OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Number of APs."
      ::= { ruckusZDWLANEntry 11 }
      ruckusZDWLANNumSta OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Number of client devices."
      ::= { ruckusZDWLANEntry 12 }
      ruckusZDWLANRxPkts OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Received packets."
      ::= { ruckusZDWLANEntry 13 }
      ruckusZDWLANRxBytes OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Received bytes."
      ::= { ruckusZDWLANEntry 14 }
      ruckusZDWLANTxPkts OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Transmitted packets."
      ::= { ruckusZDWLANEntry 15 }
      ruckusZDWLANTxBytes OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Transmitted bytes."
      ::= { ruckusZDWLANEntry 16 }
      ruckusZDWLANAssocNumSta OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Number of associate client devices, include authorize and unauthorize."
      ::= { ruckusZDWLANEntry 20 }
      ruckusZDWLANAuthTotal OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Accumulated total number of attempt to authenticate by wireless terminals on this WLAN,
      or Authentication request."
      ::= { ruckusZDWLANEntry 26 }
      ruckusZDWLANAuthResp OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Authentication response."
      ::= { ruckusZDWLANEntry 27 }
      ruckusZDWLANAuthSuccessTotal OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Accumulated total number of success out of Wireless authentication attempts."
      ::= { ruckusZDWLANEntry 28 }
      ruckusZDWLANAuthFail OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Authentication fail."
      ::= { ruckusZDWLANEntry 29 }
      ruckusZDWLANAssocTotal OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Accumulated total number of access of wireless terminal on this WLAN,
      or Association request."
      ::= { ruckusZDWLANEntry 30 }
      ruckusZDWLANAssocResp OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Association response."
      ::= { ruckusZDWLANEntry 31 }
      ruckusZDWLANReassocReq OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Reassociation request."
      ::= { ruckusZDWLANEntry 32 }
      ruckusZDWLANReassocResp OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Reassociation response."
      ::= { ruckusZDWLANEntry 33 }
      ruckusZDWLANAssocSuccess OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Association success."
      ::= { ruckusZDWLANEntry 34 }
      ruckusZDWLANAssocFail OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Association fail."
      ::= { ruckusZDWLANEntry 35 }
      ruckusZDWLANAssocDenied OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Association denied."
      ::= { ruckusZDWLANEntry 36 }
      ruckusZDWLANDiassocAbnormal OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Disassociation request due to abnormal causes."
      ::= { ruckusZDWLANEntry 37 }
      ruckusZDWLANDiassocCapacity OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Disassociation request due to device capacity."
      ::= { ruckusZDWLANEntry 38 }
      ruckusZDWLANDiassocLeave OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Disassociation request due to client leave."
      ::= { ruckusZDWLANEntry 39 }
      ruckusZDWLANDiassocMisc OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Disassociation request due to other reasons."
      ::= { ruckusZDWLANEntry 40 }
      ruckusZDWLANRxByteRate OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Received rate byte/s in last 5 minutes ."
      ::= { ruckusZDWLANEntry 41 }
      ruckusZDWLANTxByteRate OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Transmitted rate byte/s in last 5 minutes ."
      ::= { ruckusZDWLANEntry 42 }
      ruckusZDWLANRxDataFrameOnLan OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Received Data Frame Number on Lan interface ."
      ::= { ruckusZDWLANEntry 43 }
      ruckusZDWLANRxByteOnLan OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Received Data Bytes on Lan interface ."
      ::= { ruckusZDWLANEntry 44 }
      ruckusZDWLANTxByteOnLan OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Transmitted Data Bytes on Lan interface ."
      ::= { ruckusZDWLANEntry 45 }
      ruckusZDWLANDownDropFrame OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Drop Frame Number on Downlink of Wireless."
      ::= { ruckusZDWLANEntry 46 }
      ruckusZDWLANDownRetxFrame OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Retransmitted Frame Number on Downlink of Wireless."
      ::= { ruckusZDWLANEntry 47 }
      ruckusZDWLANDownTotalFrame OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Total Frame Number on Downlink of Wireless."
      ::= { ruckusZDWLANEntry 48 }
      ruckusZDWLANDownTotalErrFrame OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Total Error Frame Number on Downlink of Wireless."
      ::= { ruckusZDWLANEntry 49 }
      ruckusZDWLANUpTotalFrame OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Total Frame Number on Uplink of Wireless."
      ::= { ruckusZDWLANEntry 50 }
      ruckusZDWLANUpDropFrame OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Drop Frame Number on Uplink of Wireless."
      ::= { ruckusZDWLANEntry 51 }
      ruckusZDWLANUpRetxFrame OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Retransmitted Frame Number on Uplink of Wireless."
      ::= { ruckusZDWLANEntry 52 }
      ruckusZDWLANNAME OBJECT-TYPE
      SYNTAX RuckusSSID
      STATUS current
      DESCRIPTION
      "WLAN NAME."
      ::= { ruckusZDWLANEntry 108 }
      ruckusZDWLANAPInfo OBJECT IDENTIFIER ::= { ruckusZDWLANObjects 2 }
      ruckusZDWLANAPTable OBJECT-TYPE
      SYNTAX SEQUENCE OF RuckusZDWLANAPEntry
      STATUS current
      DESCRIPTION
      "ZD WLAN AP table."
      ::= { ruckusZDWLANAPInfo 1 }
      ruckusZDWLANAPEntry OBJECT-TYPE
      SYNTAX RuckusZDWLANAPEntry
      STATUS current
      DESCRIPTION
      "Specifies each ZD WLAN AP entry."
      INDEX {
      ruckusZDWLANAPMacAddr }
      ::= { ruckusZDWLANAPTable 1 }
      RuckusZDWLANAPEntry ::= SEQUENCE {
      ruckusZDWLANAPMacAddr MacAddress,
      ruckusZDWLANAPDescription DisplayString,
      ruckusZDWLANAPStatus INTEGER,
      ruckusZDWLANAPModel DisplayString,
      ruckusZDWLANAPSerialNumber DisplayString,
      ruckusZDWLANAPUptime TimeTicks,
      ruckusZDWLANAPSWversion DisplayString,
      ruckusZDWLANAPHWversion DisplayString,
      ruckusZDWLANAPIPAddr IpAddress,
      ruckusZDWLANAPNumRadios Unsigned32,
      ruckusZDWLANAPNumVAP Unsigned32,
      ruckusZDWLANAPNumSta Unsigned32,
      ruckusZDWLANAPNumRogues Unsigned32,
      ruckusZDWLANAPConnectionMode INTEGER,
      ruckusZDWLANAPMeshEnable TruthValue,
      ruckusZDWLANAPMeshHops Unsigned32,
      ruckusZDWLANAPMeshType INTEGER,
      ruckusZDWLANAPLANStatsRXByte Counter64,
      ruckusZDWLANAPLANStatsRXPkt Counter64,
      ruckusZDWLANAPLANStatsRXPktErr Counter64,
      ruckusZDWLANAPLANStatsRXPKTSucc Counter64,
      ruckusZDWLANAPLANStatsTXByte Counter64,
      ruckusZDWLANAPLANStatsTXPkt Counter64,
      ruckusZDWLANAPMemUtil INTEGER,
      ruckusZDWLANAPMemTotal Unsigned32,
      ruckusZDWLANAPCPUUtil INTEGER,
      ruckusZDWLANAPFWSize Unsigned32,
      ruckusZDWLANAPFWAvail Unsigned32,
      ruckusZDWLANAPMultipleVlanCapability TruthValue,
      ruckusZDWLANAP11bCapable TruthValue,
      ruckusZDWLANAP11gCapable TruthValue,
      ruckusZDWLANAPMultiModeAccessStatus TruthValue,
      ruckusZDWLANAPEthStateChange Counter32,
      ruckusZDWLANAPSyncConf TruthValue,
      ruckusZDWLANAPUpgrade TruthValue,
      ruckusZDWLANAPFirstJoinTime DisplayString,
      ruckusZDWLANAPLastBootTime DisplayString,
      ruckusZDWLANAPLastUpgradeTime DisplayString,
      ruckusZDWLANAPLastConfSyncTime DisplayString,
      ruckusZDWLANAPLANStatsRXPKTBcast Counter64,
      ruckusZDWLANAPLANStatsRXPKTMcast Counter64,
      ruckusZDWLANAPLANStatsRXPKTUcast Counter64,
      ruckusZDWLANAPLANStatsTXPKTBcast Counter64,
      ruckusZDWLANAPLANStatsTXPKTMcast Counter64,
      ruckusZDWLANAPLANStatsTXPKTUcast Counter64,
      ruckusZDWLANAPLANStatsDropped Counter64,
      ruckusZDWLANAPMeshUpPortCntUpdown Counter32,
      ruckusZDWLANAPMeshDownPortCntUpdown Counter32,
      ruckusZDWLANAPTxFrameDropped Counter32,
      ruckusZDWLANAPTxFrameError Counter32,
      ruckusZDWLANAPCoverageTech INTEGER,
      ruckusZDWLANAPStaTxBytes Counter64,
      ruckusZDWLANAPStaRxBytes Counter64,
      ruckusZDWLANAPNetmask IpAddress,
      ruckusZDWLANAPGateway IpAddress,
      ruckusZDWLANAPDNS1 IpAddress,
      ruckusZDWLANAPDNS2 IpAddress,
      ruckusZDWLANAPTotalUser Unsigned32,
      ruckusZDWLANAPLANStatsRXByteRate Counter32,
      ruckusZDWLANAPLANStatsTXByteRate Counter32
      ruckusZDWLANAPMacAddr OBJECT-TYPE
      SYNTAX MacAddress
      STATUS current
      DESCRIPTION
      "MAC address."
      ::= { ruckusZDWLANAPEntry 1 }
      ruckusZDWLANAPDescription OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Description."
      ::= { ruckusZDWLANAPEntry 2 }
      ruckusZDWLANAPStatus OBJECT-TYPE
      SYNTAX INTEGER { disconnected(0), connected(1), approvalPending(2), upgradingFirmware(3), provisioning(4) }
      STATUS current
      DESCRIPTION
      "The connection status with ZD."
      ::= { ruckusZDWLANAPEntry 3 }
      ruckusZDWLANAPModel OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Model name."
      ::= { ruckusZDWLANAPEntry 4 }
      ruckusZDWLANAPSerialNumber OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Serial number."
      ::= { ruckusZDWLANAPEntry 5 }
      ruckusZDWLANAPUptime OBJECT-TYPE
      SYNTAX TimeTicks
      STATUS current
      DESCRIPTION
      "Up time."
      ::= { ruckusZDWLANAPEntry 6 }
      ruckusZDWLANAPSWversion OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Software version."
      ::= { ruckusZDWLANAPEntry 7 }
      ruckusZDWLANAPHWversion OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Hardware version."
      ::= { ruckusZDWLANAPEntry 8 }
      ruckusZDWLANAPIPAddr OBJECT-TYPE
      SYNTAX IpAddress
      STATUS current
      DESCRIPTION
      "IP address."
      ::= { ruckusZDWLANAPEntry 10 }
      ruckusZDWLANAPNumRadios OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Number of radios."
      ::= { ruckusZDWLANAPEntry 13 }
      ruckusZDWLANAPNumVAP OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Number of APs."
      ::= { ruckusZDWLANAPEntry 14 }
      ruckusZDWLANAPNumSta OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Total number of authenticated terminal which is using currently on this AP."
      ::= { ruckusZDWLANAPEntry 15 }
      ruckusZDWLANAPNumRogues OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Number of rogue devices."
      ::= { ruckusZDWLANAPEntry 16 }
      ruckusZDWLANAPConnectionMode OBJECT-TYPE
      SYNTAX INTEGER { layer2 (0), layer3 (1) }
      STATUS current
      DESCRIPTION
      "The connection mode with ZD."
      ::= { ruckusZDWLANAPEntry 17 }
      ruckusZDWLANAPMeshEnable OBJECT-TYPE
      SYNTAX TruthValue
      STATUS current
      DESCRIPTION
      "Mesh enable."
      ::= { ruckusZDWLANAPEntry 18 }
      ruckusZDWLANAPMeshHops OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Number of mesh hops."
      ::= { ruckusZDWLANAPEntry 19 }
      ruckusZDWLANAPMeshType OBJECT-TYPE
      SYNTAX INTEGER { unknown(0), root (1), mesh (2), forming(3) }
      STATUS current
      DESCRIPTION
      "Mesh type."
      ::= { ruckusZDWLANAPEntry 20 }
      ruckusZDWLANAPLANStatsRXByte OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Bytes received on LAN port."
      ::= { ruckusZDWLANAPEntry 21 }
      ruckusZDWLANAPLANStatsRXPkt OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Packets received on LAN port."
      ::= { ruckusZDWLANAPEntry 22 }
      ruckusZDWLANAPLANStatsRXPktErr OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Packets received erroneously on LAN port."
      ::= { ruckusZDWLANAPEntry 23 }
      ruckusZDWLANAPLANStatsRXPKTSucc OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Packets received successfully on LAN port."
      ::= { ruckusZDWLANAPEntry 24 }
      ruckusZDWLANAPLANStatsTXByte OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Bytes transmitted on LAN port."
      ::= { ruckusZDWLANAPEntry 25 }
      ruckusZDWLANAPLANStatsTXPkt OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Packets transmitted on LAN port."
      ::= { ruckusZDWLANAPEntry 26 }
      ruckusZDWLANAPMemUtil OBJECT-TYPE
      SYNTAX INTEGER
      STATUS current
      DESCRIPTION
      "Memory utilization percentage."
      ::= { ruckusZDWLANAPEntry 27 }
      ruckusZDWLANAPMemTotal OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Total memory in KB."
      ::= { ruckusZDWLANAPEntry 28 }
      ruckusZDWLANAPCPUUtil OBJECT-TYPE
      SYNTAX INTEGER
      STATUS current
      DESCRIPTION
      "CPU utilization percentage."
      ::= { ruckusZDWLANAPEntry 29 }
      ruckusZDWLANAPFWSize OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Firmware partition size in byte."
      ::= { ruckusZDWLANAPEntry 30 }
      ruckusZDWLANAPFWAvail OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Firmware partition available size in byte."
      ::= { ruckusZDWLANAPEntry 31 }
      ruckusZDWLANAPMultipleVlanCapability OBJECT-TYPE
      SYNTAX TruthValue
      STATUS current
      DESCRIPTION
      "AP support multiple vlan capability."
      ::= { ruckusZDWLANAPEntry 32 }
      ruckusZDWLANAP11bCapable OBJECT-TYPE
      SYNTAX TruthValue
      STATUS current
      DESCRIPTION
      "Support 802.11b."
      ::= { ruckusZDWLANAPEntry 36 }
      ruckusZDWLANAP11gCapable OBJECT-TYPE
      SYNTAX TruthValue
      STATUS current
      DESCRIPTION
      "Support 802.11g."
      ::= { ruckusZDWLANAPEntry 37 }
      ruckusZDWLANAPMultiModeAccessStatus OBJECT-TYPE
      SYNTAX TruthValue {false(0),true(1)}
      STATUS current
      DESCRIPTION
      "Support simutaneously connections from 11a/b/g clients."
      ::= { ruckusZDWLANAPEntry 38 }
      ruckusZDWLANAPEthStateChange OBJECT-TYPE
      SYNTAX Counter32
      STATUS current
      DESCRIPTION
      "Ethernet port up/down count."
      ::= { ruckusZDWLANAPEntry 39 }
      ruckusZDWLANAPSyncConf OBJECT-TYPE
      SYNTAX TruthValue
      STATUS current
      DESCRIPTION
      "Manually push configuration to this AP."
      ::= { ruckusZDWLANAPEntry 41 }
      ruckusZDWLANAPUpgrade OBJECT-TYPE
      SYNTAX TruthValue
      STATUS current
      DESCRIPTION
      "Upgrade this AP."
      ::= { ruckusZDWLANAPEntry 42 }
      ruckusZDWLANAPFirstJoinTime OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Time of first join."
      ::= { ruckusZDWLANAPEntry 43 }
      ruckusZDWLANAPLastBootTime OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Time of last boot."
      ::= { ruckusZDWLANAPEntry 44 }
      ruckusZDWLANAPLastUpgradeTime OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Time of last firmware upgrade."
      ::= { ruckusZDWLANAPEntry 45 }
      ruckusZDWLANAPLastConfSyncTime OBJECT-TYPE
      STATUS current
      DESCRIPTION
      "Time of last configuration synchronization."
      ::= { ruckusZDWLANAPEntry 46 }
      ruckusZDWLANAPLANStatsRXPKTBcast OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Broadcast packets received successfully on LAN port."
      ::= { ruckusZDWLANAPEntry 47 }
      ruckusZDWLANAPLANStatsRXPKTMcast OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Multicast packets received successfully on LAN port."
      ::= { ruckusZDWLANAPEntry 48 }
      ruckusZDWLANAPLANStatsRXPKTUcast OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Unicast packets received successfully on LAN port."
      ::= { ruckusZDWLANAPEntry 49 }
      ruckusZDWLANAPLANStatsTXPKTBcast OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Broadcast packets transmitted successfully on LAN port."
      ::= { ruckusZDWLANAPEntry 50 }
      ruckusZDWLANAPLANStatsTXPKTMcast OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Multicast packets transmitted successfully on LAN port."
      ::= { ruckusZDWLANAPEntry 51 }
      ruckusZDWLANAPLANStatsTXPKTUcast OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Unicast packets transmitted successfully on LAN port."
      ::= { ruckusZDWLANAPEntry 52 }
      ruckusZDWLANAPLANStatsDropped OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Number of packets dropped on LAN port."
      ::= { ruckusZDWLANAPEntry 53 }
      ruckusZDWLANAPMeshUpPortCntUpdown OBJECT-TYPE
      SYNTAX Counter32
      STATUS current
      DESCRIPTION
      "updown count of AP as a up port node in mesh mode."
      ::= { ruckusZDWLANAPEntry 54 }
      ruckusZDWLANAPMeshDownPortCntUpdown OBJECT-TYPE
      SYNTAX Counter32
      STATUS current
      DESCRIPTION
      "updown count of AP as a down port node in mesh mode."
      ::= { ruckusZDWLANAPEntry 55 }
      ruckusZDWLANAPTxFrameDropped OBJECT-TYPE
      SYNTAX Counter32
      STATUS current
      DESCRIPTION
      "Droped Frame count of AP wireless transmitted."
      ::= { ruckusZDWLANAPEntry 57 }
      ruckusZDWLANAPTxFrameError OBJECT-TYPE
      SYNTAX Counter32
      STATUS current
      DESCRIPTION
      "Error Frame count of AP wireless transmitted."
      ::= { ruckusZDWLANAPEntry 58 }
      ruckusZDWLANAPCoverageTech OBJECT-TYPE
      SYNTAX INTEGER { indoor(1), indoor-distribute(2), outdoor(3) }
      STATUS current
      DESCRIPTION
      "AP's coverage technology."
      ::= { ruckusZDWLANAPEntry 59 }
      ruckusZDWLANAPStaTxBytes OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Client send data to this AP.(kbytes) "
      ::= { ruckusZDWLANAPEntry 61 }
      ruckusZDWLANAPStaRxBytes OBJECT-TYPE
      SYNTAX Counter64
      STATUS current
      DESCRIPTION
      "Client receive data from this AP.(kbytes)"
      ::= { ruckusZDWLANAPEntry 62 }
      ruckusZDWLANAPNetmask OBJECT-TYPE
      SYNTAX IpAddress
      STATUS current
      DESCRIPTION
      "Netmask address."
      ::= { ruckusZDWLANAPEntry 100 }
      ruckusZDWLANAPGateway OBJECT-TYPE
      SYNTAX IpAddress
      STATUS current
      DESCRIPTION
      "Gateway address."
      ::= { ruckusZDWLANAPEntry 101 }
      ruckusZDWLANAPDNS1 OBJECT-TYPE
      SYNTAX IpAddress
      STATUS current
      DESCRIPTION
      "Primary DNS address."
      ::= { ruckusZDWLANAPEntry 105 }
      ruckusZDWLANAPDNS2 OBJECT-TYPE
      SYNTAX IpAddress
      STATUS current
      DESCRIPTION
      "Sencond DNS address."
      ::= { ruckusZDWLANAPEntry 106 }
      ruckusZDWLANAPTotalUser OBJECT-TYPE
      SYNTAX Unsigned32
      STATUS current
      DESCRIPTION
      "Total number of client AP can support."
      ::= { ruckusZDWLANAPEntry 110 }
      ruckusZDWLANAPLANStatsRXByteRate OBJECT-TYPE
      SYNTAX Counter32
      STATUS current
      DESCRIPTION
      "Bytes rate received on LAN port each 90s."
      ::= { ruckusZDWLANAPEntry 111 }
      ruckusZDWLANAPLANStatsTXByteRate OBJECT-TYPE
      SYNTAX Counter32
      STATUS current
      DESCRIPTION
      "Bytes rate transmitted on LAN port each 90s."
      ::= { ruckusZDWLANAPEntry 112 }
      ruckusZDWLANAPRadioStatsTable OBJECT-TYPE
      SYNTAX SEQUENCE OF RuckusZDWLANAPRadioStatsEntry
      STATUS current
      DESCRIPTION
      "ZD WLAN AP Radio table."
      ::= { ruckusZDWLANAPInfo 2 }
      ruckusZDWLANAPRadioStatsEntry OBJECT-TYPE
      SYNTAX RuckusZDWLANAPRadioStatsEntry
      STATUS current
      DESCRIPTION
      "Specifies each ZD WLAN AP Radio entry."
      INDEX {
      ruckusZDWLANAPRadioStatsAPMacAddr,
      ruckusZDWLANAPRadioStatsRadioIndex }
      ::= { ruckusZDWLANAPRadioStatsTable 1 }
      • nijazse
        • Nov 2017
        • 10
        RuckusZDWLANAPRadioStatsEntry ::= SEQUENCE {
        ruckusZDWLANAPRadioStatsAPMacAddr MacAddress,
        ruckusZDWLANAPRadioStatsRadioIndex Unsigned32,
        ruckusZDWLANAPRadioStatsRadioType INTEGER,
        ruckusZDWLANAPRadioStatsChannel Unsigned32,
        ruckusZDWLANAPRadioStatsTxPower INTEGER,
        ruckusZDWLANAPRadioStatsMeshEnable TruthValue,
        ruckusZDWLANAPRadioStatsNumVAP Unsigned32,
        ruckusZDWLANAPRadioStatsNumSta Unsigned32,
        ruckusZDWLANAPRadioStatsAvgStaRSSI Integer32,
        ruckusZDWLANAPRadioStatsRxPkts Counter64,
        ruckusZDWLANAPRadioStatsRxBytes Counter64,
        ruckusZDWLANAPRadioStatsRxMulticast Counter64,
        ruckusZDWLANAPRadioStatsTxPkts Counter64,
        ruckusZDWLANAPRadioStatsTxBytes Counter64,
        ruckusZDWLANAPRadioStatsTxMulticast Counter64,
        ruckusZDWLANAPRadioStatsTxFail Counter64,
        ruckusZDWLANAPRadioStatsTxRetries Counter64,
        ruckusZDWLANAPRadioStatsPowerMgmt TruthValue,
        ruckusZDWLANAPRadioStatsMaxSta Unsigned32,
        ruckusZDWLANAPRadioStatsFrameErrorRate Unsigned32,
        ruckusZDWLANAPRadioStatsFrameRetryRate Unsigned32,
        ruckusZDWLANAPRadioStatsMonitoredTime TimeTicks,
        ruckusZDWLANAPRadioStatsTotalAssocTime Counter64,
        ruckusZDWLANAPRadioStatsAuthReq Counter64,
        ruckusZDWLANAPRadioStatsAuthResp Counter64,
        ruckusZDWLANAPRadioStatsAuthSuccess Counter64,
        ruckusZDWLANAPRadioStatsAuthFail Counter64,
        ruckusZDWLANAPRadioStatsAssocReq Counter64,
        ruckusZDWLANAPRadioStatsAssocResp Counter64,
        ruckusZDWLANAPRadioStatsReassocReq Counter64,
        ruckusZDWLANAPRadioStatsReassocResp Counter64,
        ruckusZDWLANAPRadioStatsAssocSuccess Counter64,
        ruckusZDWLANAPRadioStatsAssocFail Counter64,
        ruckusZDWLANAPRadioStatsAssocDenied Counter64,
        ruckusZDWLANAPRadioStatsDiassocAbnormal Counter64,
        ruckusZDWLANAPRadioStatsDiassocCapacity Counter64,
        ruckusZDWLANAPRadioStatsDiassocLeave Counter64,
        ruckusZDWLANAPRadioStatsDiassocMisc Counter64,
        ruckusZDWLANAPRadioStatsResourceUtil Unsigned32,
        ruckusZDWLANAPRadioStatsRxSignalFrm Counter64,
        ruckusZDWLANAPRadioStatsTxSignalFrm Counter64,
        ruckusZDWLANAPRadioStatsTotalSignalFrm Counter64,
        ruckusZDWLANAPRadioStatsAntennaGain Unsigned32,
        ruckusZDWLANAPRadioStatsBeaconPeriod Unsigned32,
        ruckusZDWLANAPRadioStatsRTSThreshold Unsigned32,
        ruckusZDWLANAPRadioStatsFragThreshold Unsigned32
        ruckusZDWLANAPRadioStatsAPMacAddr OBJECT-TYPE
        SYNTAX MacAddress
        STATUS current
        DESCRIPTION
        "AP MAC address."
        ::= { ruckusZDWLANAPRadioStatsEntry 1 }
        ruckusZDWLANAPRadioStatsRadioIndex OBJECT-TYPE
        SYNTAX Unsigned32
        STATUS current
        DESCRIPTION
        "Radio index of the AP."
        ::= { ruckusZDWLANAPRadioStatsEntry 2 }
        ruckusZDWLANAPRadioStatsRadioType OBJECT-TYPE
        SYNTAX INTEGER { radio11bg (0), radio11a (1), radio11ng(2), radio11na(3), radio11ac(4)}
        STATUS current
        DESCRIPTION
        "Radio type."
        ::= { ruckusZDWLANAPRadioStatsEntry 3 }
        ruckusZDWLANAPRadioStatsChannel OBJECT-TYPE
        SYNTAX Unsigned32
        STATUS current
        DESCRIPTION
        "Radio channel."
        ::= { ruckusZDWLANAPRadioStatsEntry 4 }
        ruckusZDWLANAPRadioStatsTxPower OBJECT-TYPE
        SYNTAX INTEGER { full(0), half(1), quarter(2), eighth(3) }
        STATUS current
        DESCRIPTION
        "Transmit power of radio."
        ::= { ruckusZDWLANAPRadioStatsEntry 5 }
        ruckusZDWLANAPRadioStatsMeshEnable OBJECT-TYPE
        SYNTAX TruthValue
        STATUS current
        DESCRIPTION
        "Mesh enable."
        ::= { ruckusZDWLANAPRadioStatsEntry 6 }
        ruckusZDWLANAPRadioStatsNumVAP OBJECT-TYPE
        SYNTAX Unsigned32
        STATUS current
        DESCRIPTION
        "Number of APs."
        ::= { ruckusZDWLANAPRadioStatsEntry 7 }
        ruckusZDWLANAPRadioStatsNumSta OBJECT-TYPE
        SYNTAX Unsigned32
        STATUS current
        DESCRIPTION
        "Number of stations."
        ::= { ruckusZDWLANAPRadioStatsEntry 8 }
        ruckusZDWLANAPRadioStatsAvgStaRSSI OBJECT-TYPE
        SYNTAX Integer32
        STATUS current
        DESCRIPTION
        "Average client RSSI."
        ::= { ruckusZDWLANAPRadioStatsEntry 9 }
        ruckusZDWLANAPRadioStatsRxPkts OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Received packets."
        ::= { ruckusZDWLANAPRadioStatsEntry 10 }
        ruckusZDWLANAPRadioStatsRxBytes OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Received bytes."
        ::= { ruckusZDWLANAPRadioStatsEntry 11 }
        ruckusZDWLANAPRadioStatsRxMulticast OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Received multicast packets."
        ::= { ruckusZDWLANAPRadioStatsEntry 12 }
        ruckusZDWLANAPRadioStatsTxPkts OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 13 }
        ruckusZDWLANAPRadioStatsTxBytes OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 14 }
        ruckusZDWLANAPRadioStatsTxMulticast OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Transmitted multicast packets."
        ::= { ruckusZDWLANAPRadioStatsEntry 15 }
        ruckusZDWLANAPRadioStatsTxFail OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Transmitted fail packets."
        ::= { ruckusZDWLANAPRadioStatsEntry 16 }
        ruckusZDWLANAPRadioStatsTxRetries OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Transmitted retry packets."
        ::= { ruckusZDWLANAPRadioStatsEntry 17 }
        ruckusZDWLANAPRadioStatsPowerMgmt OBJECT-TYPE
        SYNTAX TruthValue
        STATUS current
        DESCRIPTION
        "Power management enable."
        ::= { ruckusZDWLANAPRadioStatsEntry 18 }
        ruckusZDWLANAPRadioStatsMaxSta OBJECT-TYPE
        SYNTAX Unsigned32
        STATUS current
        DESCRIPTION
        "Number of max stations allowed."
        ::= { ruckusZDWLANAPRadioStatsEntry 19 }
        ruckusZDWLANAPRadioStatsFrameErrorRate OBJECT-TYPE
        SYNTAX Unsigned32
        UNITS
        "1/10000"
        STATUS current
        DESCRIPTION
        "Frame error rate."
        ::= { ruckusZDWLANAPRadioStatsEntry 20 }
        ruckusZDWLANAPRadioStatsFrameRetryRate OBJECT-TYPE
        SYNTAX Unsigned32
        UNITS
        "1/10000"
        STATUS current
        DESCRIPTION
        "Frame retry rate."
        ::= { ruckusZDWLANAPRadioStatsEntry 21 }
        ruckusZDWLANAPRadioStatsMonitoredTime OBJECT-TYPE
        SYNTAX TimeTicks
        STATUS current
        DESCRIPTION
        "Monitored time."
        ::= { ruckusZDWLANAPRadioStatsEntry 22 }
        ruckusZDWLANAPRadioStatsTotalAssocTime OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Client total association time."
        ::= { ruckusZDWLANAPRadioStatsEntry 24 }
        ruckusZDWLANAPRadioStatsAuthReq OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Authentication request."
        ::= { ruckusZDWLANAPRadioStatsEntry 25 }
        ruckusZDWLANAPRadioStatsAuthResp OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 26 }
        ruckusZDWLANAPRadioStatsAuthSuccess OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Authentication success."
        ::= { ruckusZDWLANAPRadioStatsEntry 27 }
        ruckusZDWLANAPRadioStatsAuthFail OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 28 }
        ruckusZDWLANAPRadioStatsAssocReq OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Association request."
        ::= { ruckusZDWLANAPRadioStatsEntry 29 }
        ruckusZDWLANAPRadioStatsAssocResp OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 30 }
        ruckusZDWLANAPRadioStatsReassocReq OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 31 }
        ruckusZDWLANAPRadioStatsReassocResp OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 32 }
        ruckusZDWLANAPRadioStatsAssocSuccess OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 33 }
        ruckusZDWLANAPRadioStatsAssocFail OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Association fail."
        ::= { ruckusZDWLANAPRadioStatsEntry 34 }
        ruckusZDWLANAPRadioStatsAssocDenied OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 35 }
        ruckusZDWLANAPRadioStatsDiassocAbnormal OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 36 }
        ruckusZDWLANAPRadioStatsDiassocCapacity OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 37 }
        ruckusZDWLANAPRadioStatsDiassocLeave OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 38 }
        ruckusZDWLANAPRadioStatsDiassocMisc OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPRadioStatsEntry 39 }
        ruckusZDWLANAPRadioStatsResourceUtil OBJECT-TYPE
        SYNTAX Unsigned32
        UNITS
        "percentage"
        STATUS current
        DESCRIPTION
        "Resource utilization."
        ::= { ruckusZDWLANAPRadioStatsEntry 40 }
        ruckusZDWLANAPRadioStatsRxSignalFrm OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Received signal frames."
        ::= { ruckusZDWLANAPRadioStatsEntry 41 }
        ruckusZDWLANAPRadioStatsTxSignalFrm OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Transmitted signal frames."
        ::= { ruckusZDWLANAPRadioStatsEntry 42 }
        ruckusZDWLANAPRadioStatsTotalSignalFrm OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Total signal frames."
        ::= { ruckusZDWLANAPRadioStatsEntry 43 }
        ruckusZDWLANAPRadioStatsAntennaGain OBJECT-TYPE
        SYNTAX Unsigned32
        STATUS current
        DESCRIPTION
        "Get antenna gain."
        ::= { ruckusZDWLANAPRadioStatsEntry 44 }
        ruckusZDWLANAPRadioStatsBeaconPeriod OBJECT-TYPE
        SYNTAX Unsigned32
        STATUS current
        DESCRIPTION
        "Get beacon period."
        ::= { ruckusZDWLANAPRadioStatsEntry 45 }
        ruckusZDWLANAPRadioStatsRTSThreshold OBJECT-TYPE
        SYNTAX Unsigned32
        STATUS current
        DESCRIPTION
        "Get RTS threshold."
        ::= { ruckusZDWLANAPRadioStatsEntry 46 }
        ruckusZDWLANAPRadioStatsFragThreshold OBJECT-TYPE
        SYNTAX Unsigned32
        STATUS current
        DESCRIPTION
        "Get fragment threshold."
        ::= { ruckusZDWLANAPRadioStatsEntry 47 }
        ruckusZDWLANStaInfo OBJECT IDENTIFIER ::= { ruckusZDWLANObjects 3 }
        ruckusZDWLANStaTable OBJECT-TYPE
        SYNTAX SEQUENCE OF RuckusZDWLANStaEntry
        STATUS current
        DESCRIPTION
        "ZD WLAN Station table."
        ::= { ruckusZDWLANStaInfo 1 }
        ruckusZDWLANStaEntry OBJECT-TYPE
        SYNTAX RuckusZDWLANStaEntry
        STATUS current
        DESCRIPTION
        "Specifies each ZD WLAN Station entry."
        INDEX {
        ruckusZDWLANStaMacAddr }
        ::= { ruckusZDWLANStaTable 1 }
        RuckusZDWLANStaEntry ::= SEQUENCE {
        ruckusZDWLANStaMacAddr MacAddress,
        ruckusZDWLANStaAPMacAddr MacAddress,
        ruckusZDWLANStaBSSID MacAddress,
        ruckusZDWLANStaSSID RuckusSSID,
        ruckusZDWLANStaUser DisplayString,
        ruckusZDWLANStaRadioType INTEGER,
        ruckusZDWLANStaChannel Unsigned32,
        ruckusZDWLANStaIPAddr IpAddress,
        ruckusZDWLANStaAvgRSSI Integer32,
        ruckusZDWLANStaRxPkts Counter32,
        ruckusZDWLANStaRxBytes Counter64,
        ruckusZDWLANStaTxPkts Counter32,
        ruckusZDWLANStaTxBytes Counter64,
        ruckusZDWLANStaRetries Counter32,
        ruckusZDWLANStaAssocTime TimeTicks,
        ruckusZDWLANStaRxError Counter32,
        ruckusZDWLANStaTxSuccess Counter32,
        ruckusZDWLANSta11bgReassoc Counter32,
        ruckusZDWLANStaAssocTimestamp DisplayString,
        ruckusZDWLANStaRetryBytes Counter32,
        ruckusZDWLANStaSNR Integer32,
        ruckusZDWLANStaRxDrop Counter32,
        ruckusZDWLANStaTxDrop Counter32,
        ruckusZDWLANStaTxError Counter32,
        ruckusZDWLANStaVlanID INTEGER,
        ruckusZDWLANStaAuthMode DisplayString,
        ruckusZDWLANStaSignalStrength Integer32
        ruckusZDWLANStaMacAddr OBJECT-TYPE
        SYNTAX MacAddress
        STATUS current
        DESCRIPTION
        "The station's MAC Address."
        ::= { ruckusZDWLANStaEntry 1 }
        ruckusZDWLANStaAPMacAddr OBJECT-TYPE
        SYNTAX MacAddress
        STATUS current
        DESCRIPTION
        "The MAC address of the associated AP."
        ::= { ruckusZDWLANStaEntry 2 }
        ruckusZDWLANStaBSSID OBJECT-TYPE
        SYNTAX MacAddress
        STATUS current
        DESCRIPTION
        "BSSID of WLAN."
        ::= { ruckusZDWLANStaEntry 3 }
        ruckusZDWLANStaSSID OBJECT-TYPE
        SYNTAX RuckusSSID
        STATUS current
        DESCRIPTION
        "SSID."
        ::= { ruckusZDWLANStaEntry 4 }
        ruckusZDWLANStaUser OBJECT-TYPE
        STATUS current
        DESCRIPTION
        "Logined username of the client."
        ::= { ruckusZDWLANStaEntry 5 }
        ruckusZDWLANStaRadioType OBJECT-TYPE
        SYNTAX INTEGER { radio11a (0), radio11b (1), radio11g(2), radio11ng(3), radio11na(4), radio11ac(5) }
        STATUS current
        DESCRIPTION
        "Radio type."
        ::= { ruckusZDWLANStaEntry 6 }
        ruckusZDWLANStaChannel OBJECT-TYPE
        SYNTAX Unsigned32
        STATUS current
        DESCRIPTION
        "Radio channel."
        ::= { ruckusZDWLANStaEntry 7 }
        ruckusZDWLANStaIPAddr OBJECT-TYPE
        SYNTAX IpAddress
        STATUS current
        DESCRIPTION
        "IP address."
        ::= { ruckusZDWLANStaEntry 8 }
        ruckusZDWLANStaAvgRSSI OBJECT-TYPE
        SYNTAX Integer32
        STATUS current
        DESCRIPTION
        "Averaged RSSI."
        ::= { ruckusZDWLANStaEntry 9 }
        ruckusZDWLANStaRxPkts OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "Received packets."
        ::= { ruckusZDWLANStaEntry 10 }
        ruckusZDWLANStaRxBytes OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Received bytes."
        ::= { ruckusZDWLANStaEntry 11 }
        ruckusZDWLANStaTxPkts OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANStaEntry 12 }
        ruckusZDWLANStaTxBytes OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANStaEntry 13 }
        ruckusZDWLANStaRetries OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "Transmitted retries."
        ::= { ruckusZDWLANStaEntry 14 }
        ruckusZDWLANStaAssocTime OBJECT-TYPE
        SYNTAX TimeTicks
        STATUS current
        DESCRIPTION
        "The time client has been associated."
        ::= { ruckusZDWLANStaEntry 15 }
        ruckusZDWLANStaRxError OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "Received error packets."
        ::= { ruckusZDWLANStaEntry 16 }
        ruckusZDWLANStaTxSuccess OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "Successful transmitted packets."
        ::= { ruckusZDWLANStaEntry 17 }
        ruckusZDWLANSta11bgReassoc OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "Reassociate count on B/G RF."
        ::= { ruckusZDWLANStaEntry 18 }
        ruckusZDWLANStaAssocTimestamp OBJECT-TYPE
        STATUS current
        DESCRIPTION
        "The timestamp client associated."
        ::= { ruckusZDWLANStaEntry 19 }
        ruckusZDWLANStaRetryBytes OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "Transmitted retry bytes."
        ::= { ruckusZDWLANStaEntry 20 }
        ruckusZDWLANStaSNR OBJECT-TYPE
        SYNTAX Integer32
        STATUS current
        DESCRIPTION
        "Station's Signal to Noise Ratio."
        ::= { ruckusZDWLANStaEntry 21 }
        ruckusZDWLANStaRxDrop OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "Drop transmitted packets."
        ::= { ruckusZDWLANStaEntry 22 }
        ruckusZDWLANStaTxDrop OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "Drop received packets."
        ::= { ruckusZDWLANStaEntry 23 }
        ruckusZDWLANStaTxError OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "Transmitted error packets."
        ::= { ruckusZDWLANStaEntry 24 }
        ruckusZDWLANStaVlanID OBJECT-TYPE
        STATUS current
        DESCRIPTION
        "VLAN ID of the station. 1 for not specified."
        ::= { ruckusZDWLANStaEntry 30 }
        ruckusZDWLANStaAuthMode OBJECT-TYPE
        STATUS current
        DESCRIPTION
        "Authentication mode of authenticated terminal."
        ::= { ruckusZDWLANStaEntry 80 }
        ruckusZDWLANStaSignalStrength OBJECT-TYPE
        SYNTAX Integer32
        UNITS
        "dBm"
        STATUS current
        DESCRIPTION
        "Signal strength"
        ::= { ruckusZDWLANStaEntry 81 }
        ruckusZDWiredStaTable OBJECT-TYPE
        SYNTAX SEQUENCE OF RuckusZDWiredStaEntry
        STATUS current
        DESCRIPTION
        "ZD Wired Station table."
        ::= { ruckusZDWLANStaInfo 2 }
        ruckusZDWiredStaEntry OBJECT-TYPE
        SYNTAX RuckusZDWiredStaEntry
        STATUS current
        DESCRIPTION
        "Specifies each ZD Wired Station entry."
        INDEX {
        ruckusZDWiredStaMacAddr }
        ::= { ruckusZDWiredStaTable 1 }
        RuckusZDWiredStaEntry ::= SEQUENCE {
        ruckusZDWiredStaMacAddr MacAddress,
        ruckusZDWiredStaAPMacAddr MacAddress,
        ruckusZDWiredStaIPAddr IpAddress,
        ruckusZDWiredStaIPV6Addr OCTET STRING,
        ruckusZDWiredStaVlanID INTEGER,
        ruckusZDWiredStaUserName DisplayString,
        ruckusZDWiredStaAuthState INTEGER,
        ruckusZDWiredStaAssocTime TimeTicks,
        ruckusZDWiredStaRxPkts Counter32,
        ruckusZDWiredStaRxBytes Counter64,
        ruckusZDWiredStaTxPkts Counter32,
        ruckusZDWiredStaTxBytes Counter64,
        ruckusZDWiredStaMacAddr OBJECT-TYPE
        SYNTAX MacAddress
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWiredStaEntry 1 }
        ruckusZDWiredStaAPMacAddr OBJECT-TYPE
        SYNTAX MacAddress
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWiredStaEntry 3 }
        ruckusZDWiredStaIPAddr OBJECT-TYPE
        SYNTAX IpAddress
        STATUS current
        DESCRIPTION
        "IP address."
        ::= { ruckusZDWiredStaEntry 5 }
        ruckusZDWiredStaIPV6Addr OBJECT-TYPE
        SYNTAX OCTET STRING (SIZE(2..40))
        STATUS current
        DESCRIPTION
        "IPV6 Address"
        ::= { ruckusZDWiredStaEntry 6 }
        ruckusZDWiredStaVlanID OBJECT-TYPE
        SYNTAX INTEGER (1..4094)
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWiredStaEntry 8 }
        ruckusZDWiredStaUserName OBJECT-TYPE
        SYNTAX DisplayString(SIZE(1..32))
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWiredStaEntry 9 }
        ruckusZDWiredStaAuthState OBJECT-TYPE
        SYNTAX INTEGER {Unauthorized(0), Authorized(1), Authorized-as-guest(2)}
        STATUS current
        DESCRIPTION
        "Authentication state of authenticated terminal."
        ::= { ruckusZDWiredStaEntry 10 }
        ruckusZDWiredStaAssocTime OBJECT-TYPE
        SYNTAX TimeTicks
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWiredStaEntry 11 }
        ruckusZDWiredStaRxPkts OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "Received packets."
        ::= { ruckusZDWiredStaEntry 15 }
        ruckusZDWiredStaRxBytes OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Received bytes."
        ::= { ruckusZDWiredStaEntry 16 }
        ruckusZDWiredStaTxPkts OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWiredStaEntry 17 }
        ruckusZDWiredStaTxBytes OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWiredStaEntry 18 }
        ruckusZDWLANRogueInfo OBJECT IDENTIFIER ::= { ruckusZDWLANObjects 4 }
        ruckusZDWLANRogueTable OBJECT-TYPE
        SYNTAX SEQUENCE OF RuckusZDWLANRogueEntry
        STATUS current
        DESCRIPTION
        "ZD WLAN rogue device table."
        ::= { ruckusZDWLANRogueInfo 1 }
        ruckusZDWLANRogueEntry OBJECT-TYPE
        SYNTAX RuckusZDWLANRogueEntry
        STATUS current
        DESCRIPTION
        "Specifies each ZD WLAN rogue device entry."
        INDEX {
        ruckusZDWLANRogueIndex }
        ::= { ruckusZDWLANRogueTable 1 }
        RuckusZDWLANRogueEntry ::= SEQUENCE {
        ruckusZDWLANRogueIndex InterfaceIndex,
        ruckusZDWLANRogueMacAddr MacAddress,
        ruckusZDWLANRogueSSID RuckusSSID,
        ruckusZDWLANRogueRadioType INTEGER,
        ruckusZDWLANRogueChannel Unsigned32,
        ruckusZDWLANRogueRSSI Integer32,
        ruckusZDWLANRogueType INTEGER,
        ruckusZDWLANRogueEncrypted INTEGER,
        ruckusZDWLANRogueSignalStrength Integer32
        ruckusZDWLANRogueIndex OBJECT-TYPE
        STATUS current
        DESCRIPTION
        "The index."
        ::= { ruckusZDWLANRogueEntry 200 }
        ruckusZDWLANRogueMacAddr OBJECT-TYPE
        SYNTAX MacAddress
        STATUS current
        DESCRIPTION
        "Rogue device's MAC Address."
        ::= { ruckusZDWLANRogueEntry 1 }
        ruckusZDWLANRogueSSID OBJECT-TYPE
        SYNTAX RuckusSSID
        STATUS current
        DESCRIPTION
        "SSID."
        ::= { ruckusZDWLANRogueEntry 2 }
        ruckusZDWLANRogueRadioType OBJECT-TYPE
        SYNTAX INTEGER { radio11bg (0), radio11a (1), radio11ng(2), radio11na(3), radio11ac(4) }
        STATUS current
        DESCRIPTION
        "Radio type."
        ::= { ruckusZDWLANRogueEntry 3 }
        ruckusZDWLANRogueChannel OBJECT-TYPE
        SYNTAX Unsigned32
        STATUS current
        DESCRIPTION
        "Radio channel."
        ::= { ruckusZDWLANRogueEntry 4 }
        ruckusZDWLANRogueRSSI OBJECT-TYPE
        SYNTAX Integer32
        STATUS current
        DESCRIPTION
        "RSSI."
        ::= { ruckusZDWLANRogueEntry 5 }
        ruckusZDWLANRogueType OBJECT-TYPE
        SYNTAX INTEGER { ap (0), ad-hoc (1) }
        STATUS current
        DESCRIPTION
        "The type of the rogue device."
        ::= { ruckusZDWLANRogueEntry 6 }
        ruckusZDWLANRogueEncrypted OBJECT-TYPE
        SYNTAX INTEGER { open (0), encrypted (1) }
        STATUS current
        DESCRIPTION
        "Encryption mode."
        ::= { ruckusZDWLANRogueEntry 7 }
        ruckusZDWLANRogueSignalStrength OBJECT-TYPE
        SYNTAX Integer32
        UNITS
        "dBm"
        STATUS current
        DESCRIPTION
        "Signal strength"
        ::= { ruckusZDWLANRogueEntry 11 }
        ruckusZDWLANVapTable OBJECT-TYPE
        SYNTAX SEQUENCE OF RuckusZDWLANVapEntry
        STATUS current
        DESCRIPTION
        "ZD WLAN AP table per each WLAN."
        ::= { ruckusZDWLANAPInfo 3 }
        ruckusZDWLANVapEntry OBJECT-TYPE
        SYNTAX RuckusZDWLANVapEntry
        STATUS current
        DESCRIPTION
        "Specifies each ZD WLAN vap entry."
        INDEX {
        ruckusZDWLANVapBSSID }
        ::= { ruckusZDWLANVapTable 1 }
        RuckusZDWLANVapEntry ::= SEQUENCE {
        ruckusZDWLANVapBSSID MacAddress,
        ruckusZDWLANVapPAPAddr MacAddress,
        ruckusZDWLANVapSSID RuckusSSID,
        ruckusZDWLANVapLanRxBytes Counter64,
        ruckusZDWLANVapLanTxBytes Counter64,
        ruckusZDWLANVapWlanRxBytes Counter64,
        ruckusZDWLANVapWlanTxBytes Counter64,
        ruckusZDWLANVapWlanRxErrorPkt Counter64,
        ruckusZDWLANVapWlanRxUnicastPkt Counter64,
        ruckusZDWLANVapWlanTxUnicastPkt Counter64,
        ruckusZDWLANVapWlanRxPkt Counter64,
        ruckusZDWLANVapWlanRxDropPkt Counter64,
        ruckusZDWLANVapWlanTxErrPkt Counter64,
        ruckusZDWLANVapWlanTxPkt Counter64,
        ruckusZDWLANVapWlanTxDropPkt Counter64
        ruckusZDWLANVapBSSID OBJECT-TYPE
        SYNTAX MacAddress
        STATUS current
        DESCRIPTION
        "The VAP's BSSID ,it is a MAC Address."
        ::= { ruckusZDWLANVapEntry 1 }
        ruckusZDWLANVapPAPAddr OBJECT-TYPE
        SYNTAX MacAddress
        STATUS current
        DESCRIPTION
        "The MAC address of the Parent's AP."
        ::= { ruckusZDWLANVapEntry 2 }
        ruckusZDWLANVapSSID OBJECT-TYPE
        SYNTAX RuckusSSID
        STATUS current
        DESCRIPTION
        "SSID of VAP."
        ::= { ruckusZDWLANVapEntry 3 }
        ruckusZDWLANVapLanRxBytes OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Received bytes on LAN in VAP ."
        ::= { ruckusZDWLANVapEntry 6 }
        ruckusZDWLANVapLanTxBytes OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Transmitted bytes on LAN in VAP."
        ::= { ruckusZDWLANVapEntry 7 }
        ruckusZDWLANVapWlanRxBytes OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Received bytes on WLAN in VAP ."
        ::= { ruckusZDWLANVapEntry 8 }
        ruckusZDWLANVapWlanTxBytes OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Transmitted bytes on WLAN in VAP."
        ::= { ruckusZDWLANVapEntry 9 }
        ruckusZDWLANVapWlanRxErrorPkt OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Receiveed error packet on WLAN in VAP."
        ::= { ruckusZDWLANVapEntry 11 }
        ruckusZDWLANVapWlanRxUnicastPkt OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Receiveed unicast packet on WLAN in VAP."
        ::= { ruckusZDWLANVapEntry 12 }
        ruckusZDWLANVapWlanTxUnicastPkt OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Transmitted unicast packet on WLAN in VAP."
        ::= { ruckusZDWLANVapEntry 13 }
        ruckusZDWLANVapWlanRxPkt OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Received packet on WLAN in VAP."
        ::= { ruckusZDWLANVapEntry 14 }
        ruckusZDWLANVapWlanRxDropPkt OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Received dropped packet on WLAN in VAP."
        ::= { ruckusZDWLANVapEntry 15 }
        ruckusZDWLANVapWlanTxErrPkt OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Transmitted error packet on WLAN in VAP."
        ::= { ruckusZDWLANVapEntry 16 }
        ruckusZDWLANVapWlanTxPkt OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Transmitted packet on WLAN in VAP."
        ::= { ruckusZDWLANVapEntry 17 }
        ruckusZDWLANVapWlanTxDropPkt OBJECT-TYPE
        SYNTAX Counter64
        STATUS current
        DESCRIPTION
        "Transmitted dropped packet on WLAN in VAP."
        ::= { ruckusZDWLANVapEntry 18 }
        ruckusZDWLANIfTable OBJECT-TYPE
        SYNTAX SEQUENCE OF RuckusZDWLANIfEntry
        STATUS current
        DESCRIPTION
        "ZD WLAN AP Interface table per each AP."
        ::= { ruckusZDWLANAPInfo 4 }
        ruckusZDWLANIfEntry OBJECT-TYPE
        SYNTAX RuckusZDWLANIfEntry
        STATUS current
        DESCRIPTION
        INDEX {
        ruckusZDWLANAPMac,
        ruckusZDWLANAPIfIndex }
        ::= { ruckusZDWLANIfTable 1 }
        RuckusZDWLANIfEntry ::= SEQUENCE {
        ruckusZDWLANAPMac MacAddress,
        ruckusZDWLANAPIfIndex InterfaceIndex,
        ruckusZDWLANAPIfDescr DisplayString,
        ruckusZDWLANAPIfType IANAifType,
        ruckusZDWLANAPIfMtu Integer32,
        ruckusZDWLANAPIfSpeed DisplayString,
        ruckusZDWLANAPIfPhysAddress DisplayString,
        ruckusZDWLANAPIfAdminStatus INTEGER,
        ruckusZDWLANAPIfOperStatus INTEGER,
        ruckusZDWLANAPIfInOctets Counter32,
        ruckusZDWLANAPIfInUcastPkts Counter32,
        ruckusZDWLANAPIfInNUcastPkts Counter32,
        ruckusZDWLANAPIfInDiscards Counter32,
        ruckusZDWLANAPIfInErrors Counter32,
        ruckusZDWLANAPIfInUnknownProtos Counter32,
        ruckusZDWLANAPIfOutOctets Counter32,
        ruckusZDWLANAPIfOutUcastPkts Counter32,
        ruckusZDWLANAPIfOutNUcastPkts Counter32,
        ruckusZDWLANAPIfOutDiscards Counter32,
        ruckusZDWLANAPIfOutErrors Counter32,
        ruckusZDWLANAPIfName DisplayString,
        ruckusZDWLANAPIfNameDefined DisplayString
        ruckusZDWLANAPMac OBJECT-TYPE
        SYNTAX MacAddress
        STATUS current
        DESCRIPTION
        "The AP's Mac Address."
        ::= { ruckusZDWLANIfEntry 1 }
        ruckusZDWLANAPIfIndex OBJECT-TYPE
        STATUS current
        DESCRIPTION
        "The index of Interface in AP ."
        ::= { ruckusZDWLANIfEntry 2 }
        ruckusZDWLANAPIfDescr OBJECT-TYPE
        STATUS current
        DESCRIPTION
        "The Description information for this interface."
        ::= { ruckusZDWLANIfEntry 3 }
        ruckusZDWLANAPIfType OBJECT-TYPE
        SYNTAX IANAifType
        STATUS current
        DESCRIPTION
        "The type of interface."
        ::= { ruckusZDWLANIfEntry 4 }
        ruckusZDWLANAPIfMtu OBJECT-TYPE
        SYNTAX Integer32
        STATUS current
        DESCRIPTION
        "The size of the largest packet which can be sent/received."
        ::= { ruckusZDWLANIfEntry 5 }
        ruckusZDWLANAPIfSpeed OBJECT-TYPE
        STATUS current
        DESCRIPTION
        "An estimate of the interface's current bandwidth in bits."
        ::= { ruckusZDWLANIfEntry 6 }
        ruckusZDWLANAPIfPhysAddress OBJECT-TYPE
        STATUS current
        DESCRIPTION
        "The interface's mac address."
        ::= { ruckusZDWLANIfEntry 7 }
        ruckusZDWLANAPIfAdminStatus OBJECT-TYPE
        SYNTAX INTEGER{
        up(1), -- ready to pass packets
        down(2),
        testing(3) -- in some test mode
        STATUS current
        DESCRIPTION
        "The desired state of the interface: up(1), down(2) ,testing(3) ."
        ::= { ruckusZDWLANIfEntry 8 }
        ruckusZDWLANAPIfOperStatus OBJECT-TYPE
        SYNTAX INTEGER{
        down(2),
        testing(3), -- in some test mode
        unknown(4), -- status can not be determined
        -- for some reason.
        dormant(5),
        notPresent(6), -- some component is missing
        lowerLayerDown(7) -- down due to state of
        -- lower-layer interface(s)
        STATUS current
        DESCRIPTION
        "The current operational state of the interface:
        up(1), down(2), testing(3), unknown(4), dormant(5) , notPresent(6), lowerLayerDown(7)."
        ::= { ruckusZDWLANIfEntry 9 }
        ruckusZDWLANAPIfInOctets OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "The total number of octets received on the interface."
        ::= { ruckusZDWLANIfEntry 10 }
        ruckusZDWLANAPIfInUcastPkts OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "The total number of unicast packets received on the interface."
        ::= { ruckusZDWLANIfEntry 11 }
        ruckusZDWLANAPIfInNUcastPkts OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "The total number of multicast and broadcast packets received on the interface."
        ::= { ruckusZDWLANIfEntry 12 }
        ruckusZDWLANAPIfInDiscards OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "The number of inbound packets which were chosen to be discarded even though no errors had been detected ."
        ::= { ruckusZDWLANIfEntry 13 }
        ruckusZDWLANAPIfInErrors OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "The number of inbound packets that contained errors."
        ::= { ruckusZDWLANIfEntry 14 }
        ruckusZDWLANAPIfInUnknownProtos OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "The number of packets received via the interface which were discarded because of an unknown or unsupported protocol."
        ::= { ruckusZDWLANIfEntry 15 }
        ruckusZDWLANAPIfOutOctets OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "The total number of octets transmitted out of the interface."
        ::= { ruckusZDWLANIfEntry 16 }
        ruckusZDWLANAPIfOutUcastPkts OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "The total number of unicast packets transmitted out of the interface."
        ::= { ruckusZDWLANIfEntry 17 }
        ruckusZDWLANAPIfOutNUcastPkts OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "The total number of multicast and broadcast packets transmitted out of the interface."
        ::= { ruckusZDWLANIfEntry 18 }
        ruckusZDWLANAPIfOutDiscards OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "The number of outbound packets which were chosen to be discarded even though no errors had been detected."
        ::= { ruckusZDWLANIfEntry 19 }
        ruckusZDWLANAPIfOutErrors OBJECT-TYPE
        SYNTAX Counter32
        STATUS current
        DESCRIPTION
        "The number of outbound packets that could not be transmitted because of errors."
        ::= { ruckusZDWLANIfEntry 20 }
        ruckusZDWLANAPIfName OBJECT-TYPE
        STATUS current
        DESCRIPTION
        "The name of interface."
        ::= { ruckusZDWLANIfEntry 21 }
        ruckusZDWLANAPIfNameDefined OBJECT-TYPE
        STATUS current
        DESCRIPTION
        "The alias of interface."
        ::= { ruckusZDWLANIfEntry 22 }
        ruckusZDWLANAPEthStatusTable OBJECT-TYPE
        SYNTAX SEQUENCE OF RuckusZDWLANAPEthStatusEntry
        STATUS current
        DESCRIPTION
        "ZD WLAN AP Ethernet Interface status table per each AP."
        ::= { ruckusZDWLANAPInfo 8 }
        ruckusZDWLANAPEthStatusEntry OBJECT-TYPE
        SYNTAX RuckusZDWLANAPEthStatusEntry
        STATUS current
        DESCRIPTION
        "Specifies each ZD WLAN AP ethernet interface status entry."
        INDEX {
        ruckusZDWLANAPMacAddress,
        ruckusZDWLANAPEthPortId }
        ::= { ruckusZDWLANAPEthStatusTable 1 }
        RuckusZDWLANAPEthStatusEntry ::= SEQUENCE {
        ruckusZDWLANAPMacAddress MacAddress,
        ruckusZDWLANAPEthPortId INTEGER,
        ruckusZDWLANAPEthIfname OCTET STRING,
        ruckusZDWLANAPEthDot1xStatus INTEGER,
        ruckusZDWLANAPEthLogicalStatus INTEGER,
        ruckusZDWLANAPEthPhyStatus INTEGER,
        ruckusZDWLANAPEthPhyIfSpeed INTEGER,
        ruckusZDWLANAPEthPhyLinkStatus INTEGER,
        ruckusZDWLANAPEthLabel OCTET STRING
        ruckusZDWLANAPMacAddress OBJECT-TYPE
        SYNTAX MacAddress
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPEthStatusEntry 1 }
        ruckusZDWLANAPEthPortId OBJECT-TYPE
        SYNTAX INTEGER
        STATUS current
        DESCRIPTION
        "The ap ethernet port id."
        ::= { ruckusZDWLANAPEthStatusEntry 2 }
        ruckusZDWLANAPEthIfname OBJECT-TYPE
        SYNTAX OCTET STRING
        STATUS current
        DESCRIPTION
        ::= { ruckusZDWLANAPEthStatusEntry 5 }
        ruckusZDWLANAPEthDot1xStatus OBJECT-TYPE
        SYNTAX INTEGER {
        auth(1),
        supp(2),
        none(3) }
        STATUS current
        DESCRIPTION
        "The ap ethernet port Dot1xStatus."
        ::= { ruckusZDWLANAPEthStatusEntry 6 }
        ruckusZDWLANAPEthLogicalStatus OBJECT-TYPE
        SYNTAX INTEGER {
        up(1),
        down(2) }
        STATUS current
        DESCRIPTION
        "The ap ethernet port logical status."
        ::= { ruckusZDWLANAPEthStatusEntry 7 }
        ruckusZDWLANAPEthPhyStatus OBJECT-TYPE
        SYNTAX INTEGER {
        up(1),
        down(2) }
        STATUS current
        DESCRIPTION
        "The ap ethernet port physical status."
        ::= { ruckusZDWLANAPEthStatusEntry 8 }
        ruckusZDWLANAPEthPhyIfSpeed OBJECT-TYPE
        SYNTAX INTEGER
        STATUS current
        DESCRIPTION
        "The ap ethernet interface's current bandwidth in Mbits,."
        ::= { ruckusZDWLANAPEthStatusEntry 9 }
        ruckusZDWLANAPEthPhyLinkStatus OBJECT-TYPE
        SYNTAX INTEGER {
        full(1),
        half(2) }
        STATUS current
        DESCRIPTION
        "The ap ethernet port physical link status."
        ::= { ruckusZDWLANAPEthStatusEntry 10 }
        ruckusZDWLANAPEthLabel OBJECT-TYPE
        SYNTAX OCTET STRING
        STATUS current
        DESCRIPTION
        "The ap ethernet port label."
        ::= { ruckusZDWLANAPEthStatusEntry 11 }
        END
        • kloczek
          • Jun 2006
          • 1771
          Just try use on such OID snmpwalk command,
          BTW copy of the MIB file to the /usr/share/snmp/mibs it is not all what you need to do.
          MIB file needs to be added in the net-snmp configuration by for example put in /etc/snmp/snmp.local.conf file line:
          mibs +<NAME-OF-YOUR-MIB>
          • nijazse
            • Nov 2017
            • 10
            I used snmpwalk command on this OID and i get correct results.
            Also, i edited net-snmp configuration in /etc/snmp/snmp.conf file and included MIB files. I posted screenshot, hope my configuration is OK?
            Zabbix item is still Not supported. It still displays the message that item is not supported (SNMP error: (noSuchName) There is no such variable name in this MIB.)
            • troffasky
              • Jul 2008
              • 631
              It sounds like Zabbix is not picking up the MIB you have installed locally. You could restart Zabbix server and look for errors mentioning this MIB.
              • nijazse
                • Nov 2017
                • 10
                I did LLD using this OID and all work well.
                I can see the results and they are accurate.
                Where can i look for errors about this MIB? Is there a log file, or?
                When i restart the server i didnt get any errors.
                • kloczek
                  • Jun 2006
                  • 1771
                  IAlso, i edited net-snmp configuration in /etc/snmp/snmp.conf file and included MIB files. I posted screenshot, hope my configuration is OK?
                  Adding some entries to snmp.local.conf allows keep snmp.conf untouched as usually this file is installed and updated by package manager.
                  Simple snmp.local.conf is parsed after snmp.conf.
                  Keeping all local changes into separated files allow easier to move those changes around, keep track of those changes or making backup.
                  • troffasky
                    • Jul 2008
                    • 631
                    I wouldn't expect to see errors on the CLI. When Zabbix doesn't like the MIBs I feed it, it fills the server log with errors about the particular MIB.
