Juniper RPM - Paket Loss
  • ariek
    • Jul 2017
    I'm using Juniper - RPM SLA templet to monitor Paketloss and RTT.
    the Packetloos using the templet is juniper.ipsla.loss[{#ADVSNMPINDEXTEXT2}] SNMP OID 1.3.6.1.4.1.2636.3.50.1.2.1.4.{#ADVSNMPINDEX2}
    the problem that i facing is that this SNMP look like doing snmpwalk on the index and log to database the last integer while when donig snmpwalk on the router CLI we geeting 3 option of current , last and total avr.
    for ex.
    labroot@acx1000-r2002> show snmp mib walk 1.3.6.1.4.1.2636.3.50.1.2.1.4
    jnxRpmResSumPercentLost.4.84.69.83.84.6.84.69.83.8 4.95.65.1 = 100 <<<< Current Test
    jnxRpmResSumPercentLost.4.84.69.83.84.6.84.69.83.8 4.95.65.2 = 0
    jnxRpmResSumPercentLost.4.84.69.83.84.6.84.69.83.8 4.95.65.4 = 0
    the Zabbix log to his database the last one , while i need the firs result.
    I try to change the OID to reflect 1.3.6.1.4.1.2636.3.50.1.2.1.4.{#ADVSNMPINDEX2}.1
    but geeting no OID support in the item info.
    any suggest
    thanks
  • kaspars.mednis
    • Oct 2017
    • 349
    have you checked that {#ADVSNMPINDEX2} is translated to
    exactly ?
    Did you get right result with snmpget commandline utility on this OID?
    1.3.6.1.4.1.2636.3.50.1.2.1.4.4.84.69.83.84.6.84.69.83.8 4.95.65.1
