quickly clear "resolved" issues from dashboard
  • ssj
    • Jan 2018
    hi,
    in zabbix it continues to display "resolved" status issues for sometime before clearing it (please refer the attached screenshot).
    is it possible to clear the resolved issues immediately or within few seconds ?
    TIA
  • Ben488
    • Nov 2017
    Is this what you are looking for?
    • allexpetrov
      • May 2017
      • 361
      Hi there,
      Change the Administration->General->Trigger displaying options from 30m to 0 and this should od the trick.
      Regards,
      Alex!
      • ssj
        • Jan 2018
        @allexpetrov thanks. it worked.
