If using a template, you could clear and unlink the template, and then relink it. However, if the problem still exists the triggers will re-fire. If you did not use a template, just blow away the trigger on the host, and then recreate it if it still needed. If you recreated it, and the problem still exists it will fire again as well.
New versions of Zabbix have the ability to manually close a fired trigger. The trigger has to be configured for this (before it has fired) - just tick the "Allow manual close" option in the trigger config.
In short, don't have triggers for things that are not actionable.
