High ICMP ping loss - icmppingloss
  • me2017
    • Apr 2017
    • 34
    Since updating zabbix to 3.4 I'm seeing a persistent 'Problem' of 'High ICMP ping loss' This is reported only on a single host, the zabbix server.
    I'm having difficulty diagnosing the root cause. I've tried to use 'zabbix_get' but my results are the same as what appears in the post below 'ZBX_NOTSUPPORTED: Unsupported item key.'
    I have removed and replaced the template, and also verified fping location and permissions, but this resulted in the same 'Problem' of 'High ICMP ping loss' reappearing.
    What else can I do to diagnose the issue?
    https://blog.zabbix.com/forum/showthread.php?t=58716
  • LenR
    • Sep 2009
    • 1010
    On the host interface for the server, it it using IP or DNS? Is the IP or DNS correct? Is it self monitored or monitored by a proxy?
    zabbix_get only works for zabbix agent items, icmpping* are simple checks.
    • me2017
      • Apr 2017
      • 34
      Thank you for the clarification on 'simple checks.' I didn't realize this was the case.
      As for the host interface, I think you're referring to 'Configuration -> Hosts' If so, the host is configured with just the hostname / DNS. I don't have a proxy in place so it's self monitored.
      I will try replacing DNS as the interface and use IP.
      Again, of all the items/triggers I have set in this environment, this is the only one failing.
      https://www.zabbix.com/documentation.../simple_checks
      • LenR
        • Sep 2009
        • 1010
        I seem to remember long ago that some hardware couldn't ping it's own public interface, but I haven't seen that recently. I always set my server and proxy as the localhost IP.
