zabbix_server.conf, i set PingerFrequency to 60s
Using Simple check for a few hosts, Host is using IP address to monitor.
i edited the hosts file as well, ip address of host, hostname i use in zabbix, no use.
Item ping i also set to update every interval of 60s..
Item Ping with icmpping return value of 1, but availability is unknown ?
Why is this so?
Have search through the forums, but found no solution.
On Zabbix-1.1.6, with Fc5
Why is this so?
