ZabbixW32 Agent
  • pnicolosi78
    • Dec 2004
    • 24
    ZabbixW32 Agent
    The ZabbixW32 Agent in the services control panel just says starting, it never fully starts and I can't get any information from the server. I've tried multiple it using multiple ports. Still same results.Any ideas?
  • ianshot
    • Apr 2005
    Did you run zabbixw32.exe check-config? If so did it have a problem?
    Also try running zabbixw32.exe standalone in a command prompt window. This helped me find that I had to switch the port from 10000, to something else.
    • qong01
      • Jun 2005
      Same Here
      I got into the same issue.
      Not sure of what else to do.
      I confirmed that no other process is using that port but still the same thing. Process just hangs at starting.
      any help in this.
      • aogail
        • Jun 2006
        Bump
        I'm also having this issue. Did anyone discover a cause or solution?
        I get the following when running the agent standalone:
        C:\>zabbixw32 standalone
        Using configuration file "C:\zabbix_agentd.conf"
        Configuration file OK
        At this point, it hangs. Attempting to connect to the agent yields connection refused.
        • dantheman
          • May 2006
          • 209
          Have you tried running zabbixw32 check-config ? Also I know one thing I had an issue with, the log file is set for a linux filename, I had to change that to a windows compatible filename and then it worked.
